07-21-2008, 09:38 PM   #1
M-lens uses with flash
Anyone has a decent trick for use of M lens with flash photography?
07-21-2008, 11:06 PM   #2
pasipasi's Avatar
I use my M lenses with my AF280t flash and it's quite easy. I Put the camera in manual mode and the flash in half-automatic mode, set the aperture to what I think is right for shooting with the flash in those conditions and fire away. I'm not sure though what'd it be like with a newer flash though.
07-22-2008, 06:18 AM   #3
AFAIK the built-in flash always blasts on full for M lenses, so I just click away a few test shots in Manual mode, turning the aperture ring until it looks nice. Cut open fuji film canister makes a good diffuser, a bit of foil in the canister makes it bounce upwards.. Makes for a light travel setup.
with external flash I use 'auto' mode on the flash, and set the camera aperture accordingly.
07-22-2008, 07:11 AM   #4
Grab a 540 and shoot in AUTO (not P-TTL) mode. Match up the ISO/f-stop between the flash and camera. Should work great!
07-22-2008, 12:23 PM   #5
what about the built-in flash?
Anyone has a good tip to spare for the built-in flash to be used with M lens?
the built-in flash is marvelous for very slight fill-in and to put sparkles on things. But it tends to fire at full power when coupled with M lens and won't throttle down correctly like an external flash could.... maybe it's just a limitation of this flash.
07-22-2008, 12:55 PM   #6
Read Mark's post above. It doesn't just "tend" to fire at full power with an M lens, it WILL ALWAYS fire at full power. Only solution is to use a smaller f-stop to limit how much light hits the sensor.
07-22-2008, 04:02 PM   #7
Igilligan
Guest
Or tape some TP over the on-board full power flash....
flash, k-mount, pentax lens, slr lens
For Sale - Sold: Pentax AF200S flash, Vivitar 2800 macro flash, Lowepro Lens case 4 Light_Horseman Sold Items 8 03-06-2010 10:13 AM
For Sale - Sold: K20D, 16x45mm lens, 50mm (manual) lens, FGZ540 flash pentaxshooter Sold Items 0 09-21-2008 03:21 PM
Lens/Flash Incompatbility? Parallax Pentax DSLR Discussion 2 06-08-2008 10:35 AM
Flash with tele lens gkopeliadis Photographic Technique 7 04-16-2008 01:53 AM
lens or flash, lens or flash? ghost Pentax SLR Lens Discussion 6 03-30-2008 05:39 PM
All times are GMT -7. The time now is 01:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
