Originally posted by talkskiwon I just tested the 60-250 yesterday at a lake area and it didn't stretch far enough even when I was shooting an object very far away from me. I'm not sure if I did anything wrong, but does the focus breathing happen to far objects as well?
Hi talkskiwon. I will try to explain what is happening with the focus breathing. When you have your 60-250 zoomed to 250mm focused on an object in the distance, and it is in focus when the focus ring is on infinity, your field of view with the lens is for a 250mm. As you bring the focus down closer to minimum focusing distance, the image will blur as it should, but what also happens is the image gets smaller. The field of view of the lens increases with focus. This is because with an internal focus lens, the elements are moving inside the barrel and the lens elements are at their longest point from each other at 250. If you watch the You Tube I posted, you will notice that the 200mm zoom at 200mm focused on the tree at infinity is quite large. As the focus ring is moved towards minimum focus, the image size of the tree gets smaller as the focus gets worse. The 200mm setting looks more like 180mm or 170mm. That is focus breathing. So anything at the 200mm setting at the minimum focusing distance looks like it was taken with a 170mm lens. I hope I have explained this properly to you. Watch the video a couple of times and see if that helps too. Post again if you need more help.
---------- Post added 14-08-16 at 05:18 PM ----------
Note - Disregard the blurring, and only look at the image size change from infinity focus to minimum focus on the distant tree image at the 200mm zoom setting on the video.
