Originally posted by benny2nd Hello from a new member
Hello, welcome!
Originally posted by benny2nd To my best abilities I've tried to focus to infinty, and whatever I do I'm not able do better than the attached F2.8 photo. This actual shot is taken with the help of focus peaking in live view, which is about the same result I get if I try to do it fully manually. The camera is on a weighed down tripod (shortest legs), shake reduction off, 2 sec timer (not remote though).
So this might be the first problem. The focus ring is usually miscalibrated on this lens, so the numbers are unreliable. Secondly, live view often stops down the lens, so you are not really focusing at f2.8. And focus peaking with this lens is unreliable because it shows a massive DoF, which is too generous at f2.8.
How to focus Samyang 14mm: take test photos. Select M mode on camera, f2.8, lowest ISO, 2 sec timer, put it on tripod, aim it at something that is near the horizon and take test photos, then remember where each one was focused and look at them on computer at 100% zoom. This was how I figured out where my Samyang 14mm is actually focused to infinity (around the 3m mark). This alone will fix most of the problems. There are some videos online on blogs and youtube about how to manually calibrate the focus ring on this lens (because it is such a common problem). You can check them out, it is not too difficult. I never bothered with mine, even though I should do it eventually.
How to find optical problems: Ok, your first photo is either completely misfocused (focused past infinity, most likely, as this lens allows you to focus past infinity and make literally everything OoF) or the lens has some problems. Most common problem with this lens is decentering. This is often a problem for fast ultrawide lenses and can usually be diagnosed by the edges of the photo. One part of the photo will be in focus, but another will be soft, and the CA will be different on different sides of the frame. Often the DoF will be diagonal, instead of parallel. Most people who notice this, send the lens back and get another copy. And possibly send that one back, as well. I know a couple of forum members here had to return multiple Samyang 14mm to get a good one. My first copy was decentered. My second copy is slightly less decentered, so I kept it. I don't know if a shop can fix this for you or not.
However! I would recommend you first check the lens. Make sure the front glass element and especially the back are both clean. Don't wipe them with a harsh cloth - check online for instructions on how to clean a lens. Make sure there is no filter or teleconverter or anything like that mounted. After you clean it, check the focus calibration. Maybe you can reach infinity by 2m, and the lens is fine. Finally, take photos of something parallel (wall, newspaper, things like that) to the lens at f2.8 and check the edges. Remember, the DoF is always curved, but the edges should still all look relatively similar, even if they are different from the centre. But if one half of the photo, or one edge of the photo looks noticeably worse than another, then there is probably decentering. I recommend you do this test near the minimum focus distance of the lens, as it is more easy to detect problems and set up the whole rig. You can try using Catch in focus, but I would generally only recommend focus peaking with this lens when you are really near the minimum focus distance. Even 1m and further the FP is almost useless.
Tl;dr: My Samyang 14mm is much sharper at f2.8, it is very sharp. Either you misfocused or your lens is dirty or your lens has some sort of damage. Clean it, calibrate the focusing, do some tests, then have it sent to a repair shop or return it to seller (or have seller pay part of the repair costs). Good luck.
There is a Samyang lens club thread on these forums, and possibly you can find an f2.8 photo on my 500px gallery (but I usually shoot this lens at f8, where it is super sharp and has huge DoF). You will see they are sharp. But note that I do add some digital sharpening.
