Originally posted by Belgarchi Steve, thanks for the suggestion, you were right... My beloved lens is foggy inside (as well as my 20/2.8 FA ; and of course all my cheaper lenses are fine)
I hope it is not fungus, no 'linear' features, it looks like vapor... any suggestions before I go to the repair shop? Haidryer? Dehumidifier? Sun bath?
I am not able to open the lens, I am affraid I will not be able to assemble it perfectly after cleaning.
---------- Post added 08-26-16 at 12:19 PM ----------
I wondered why it is ok at f/5.6? Well, the 'fog' is on the periphery, the central area is clean.
Before you take it to a repair shop you should try putting the lens in a sealed container with some packets of moisture absorbent silica gel desiccant. My fa50 fogged so I put it in a ziplock bag with some packets and left it for a couple of days and it worked like a charm. Try it. If it works it costs you next to nothing. If it is fungus then I suggest that you rethink your storage methods.
I live in a country with very humid conditions and learned the hard way that leaving lenses in draws or bags in a humid climate is asking for trouble. In my first year here 2 lenses that I didn't use turned green inside. Fortunately I did not keep those lenses with my others as they probably would have been infected with fungus also. My quick and easy solution was to buy a small dry cabinet and no problems since. If you do a search on this site or on the internet you will find lots of info about storing lenses.
