08-31-2016, 08:48 AM   #1
sarge's Avatar
Some questions about using manual focus lenses on K-3 II
I am thinking about picking up a Samyang 85 1.4 lens. I have a couple of questions.
1. If I am correct it has the "A" option on aperture ring. Will this allow me to set the lens with the camera controls? Will it meter by pressing shutter button?
2. Will I have to let the camera know what focal length is on the camera each time I mount it?
3. Will focus peaking work in LV?
4. Can I set up one of the User modes for this lens so I can switch to that mode each time I mount the lens so I can work quickly?
Thanks for your help!
08-31-2016, 09:12 AM   #2
UncleVanya's Avatar
QuoteOriginally posted by sarge Quote
1) Yes it has an A button - my Rokinon 8mm Fisheye is the same manufacturer and I use it that way all the time. Av mode allows control of the aperture as does any mode (M, HyP, etc) that permits you to control aperture - Tv works allowing the camera to set the Aperture as does P etc.
2) No - you have to supply focal length - the A series lens mount standard does not include any CPU in the lens to communicate this info from. It is able to passively tell the camera the max aperture and that's all it needs to know to allow for aperture automation.
3) It should - it does for me.
4) I don't recall - I have not tried this. I am 99.99% sure that this will not set the focal length for shake reduction / exif. You will likely need to set that via menu or turn off and on the camera to be prompted.
08-31-2016, 09:13 AM   #3
amateur dirt farmer
pepperberry farm's Avatar
1. If I am correct it has the "A" option on aperture ring. Will this allow me to set the lens with the camera controls? Will it meter by pressing shutter button? yes
2. Will I have to let the camera know what focal length is on the camera each time I mount it? every time you turn the camera on with that lens mounted, yes
3. Will focus peaking work in LV? don't know- don't use LiveView that often
4. Can I set up one of the User modes for this lens so I can switch to that mode each time I mount the lens so I can work quickly? yes
see above....
08-31-2016, 09:15 AM   #4
sundr's Avatar
Yes "A" will give you full functionality of all the modes. You don't have to stop-down for metering. Peaking works and focus indicator through the view finder. You do have to input the focal length. Unsure about the user mode question, but, I don't think focal length is one of the settings that can be saved.
08-31-2016, 10:08 AM - 1 Like   #5
Otis Memorial Pentaxian
QuoteOriginally posted by sundr Quote
...with one small qualifier applicable to all KA mount lenses in regards to P-TTL flash. P-TTL works best when it has detailed information regarding focus distance via the "data" pin on the lens mount (found on AF lenses only). Without that information, pre-flash intensity is not tailored to subject distance. The result is a "fault state" at high ISO and/or close distance where the flash fails over to full intensity regardless of the pre-flash metering.
In general use, this is usually not a problem, but should be anticipated when doing closeup work.
08-31-2016, 11:22 AM   #6
BigMackCam's Avatar
I could be mistaken here, but aren't there two versions of the 85 /1.4? One with auto aperture control and one without? Worth making sure when ordering... I know the one I have in Sony A-mount doesn't have it.
08-31-2016, 01:31 PM - 1 Like   #7
THoog's Avatar
The non-Pentax versions of the 85mm may or may not have auto-aperture, but the K-mount version has always had A contacts and auto-aperture control - I have an early gold-band copy, and it is KA-mount. They can do this because all it requires is a couple dimples filled with epoxy resin on the mount plate - no electronics or additional linkages.
Because many (most? all?) sellers of Samyang/Roki/Bow/Viv/etc. lenses only use one picture for all versions of each lens - usually a Nikon-mount - the legend persists that there are K- and KA- versions, even in new designs. Every one of my SamRokBowinon lenses is KA-mount. It wouldn't make sense for Samyang to split the small K-mount production even smaller with K- and KA- versions, and no one has ever posted photos of an actual K-but-not-KA SamRokBowinon lens - they always turn out to be F-mount.
08-31-2016, 01:34 PM   #8
BigMackCam's Avatar
^^^ Thanks, Todd - you've cleared up something that has confused me for some time!
camera, focus, focus lenses, k-mount, lens, lenses on k-3, pentax lens, questions, slr lens, time
Questions about remotes for pentax k 3 and k 5 II aslyfox Troubleshooting and Beginner Help 18 08-24-2016 08:50 PM
Questions about legacy glass on K-3 II sarge Pentax SLR Lens Discussion 5 02-18-2016 11:45 AM
K-3 Retaining (incorrect) Lens Data Using Manual Lenses? Sagitta Troubleshooting and Beginner Help 14 04-16-2015 10:24 AM
Some questions about K-3 settings zzeitg Pentax K-3 3 10-10-2014 02:31 AM
Questions about using M42 lenses - focus and metering Spodeworld Troubleshooting and Beginner Help 23 10-12-2011 10:01 AM
All times are GMT -7. The time now is 03:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
