Originally posted by sarge I have noticed the front part of my 18-55 WR lens has quite a bit of wobble...
Is this something I should concern myself with? ...
Can you still get it to properly focus?
I don't have the 18-55 but I had 2 lenses that one day its front element showed sign of wobble.
DA 15, It wobbled a lot and unable to lock the focus. I open the front part of the lens and found out that it has 3 screws loosen inside. Put all of them back and things are working ok. No wobble and focus working find again until now.
FA20, unlike the limited lens, DA15, the FA20 has a little bit of wobble in the front elements since I got it. And one day it wobbled a lot and unable to lock focus. I took it to Pentax service center because I cannot find a way to open it up. They said the internal mechanism seem to be broken beyond fix! And that was it for my most used lens.
If your lens wobbles more than usual, and if you can find a service center, have them look at it. Don’t open it yourself unless you know what you are doing. A few screw might be loosen inside like my DA15.
