Originally posted by MJKoski This is somewhat disappointing as Irix 15mm would probably be as good as the Penron at 15mm with 33% the cost. Zeiss 28/2 stopped to f/4 walks over the zoom and I expect the new Samyang 20/1.8 to be supreme choice as well.
Sure, and the Samyang 14mm f2.8, Samyang 24mm f1.4, Pentax F 28mm, Zeiss 25mm,.. but those are all primes. They should have some advantages over a zoom lens - size, overall optical quality, aperture. If none of those, then at least price should be much lower. Still, I don't own a DFA 15-30mm, but I have seen some really nice sample photos. I mostly shoot wide angle with primes, but this lens is really tempting me to try a zoom, as it shows that zooms have come a long way.
I would recommend you check the lens for fingerprints or dirt, especially the back element. Check the lens for back/front focus. Make sure the distance scales are not miscalibrated, if you are planning on using those (for astrophoto and night time landscapes, you kind of have to rely on these). Make sure you are not using UV filters and make sure you are using the lens hood. Finally, make sure the lens does not suffer from decentering. There are numerous threads about this. It is an issue that is most commonly a problem with UWA lenses. Take some test photos wide open of a subject near the minimum focus distance, something like a book or newspaper placed 45 degrees to the camera sensor. It has to be further than the MFD, but not very far. Shoot Av mode, wide open aperture, 2 sec timer, low ISO, hopefully in good, bright natural light, and use Live view with Focus peaking to manually focus. Then compare the result, check the DoF and sharpness.
Feel free to upload samples from your lens in this thread, hopefully with intact exif data and 100& crops
