09-07-2016, 07:50 AM   #1
If you were to take one lens to shoot landscapes...
What would it be?
I'm thinking what lens would be a good choice for me to start building my collection. So far I'm leaning towards 24-70 2.8 as it seems it'll give me a lot of flexibility on hikes and travels, and I can take maybe two-three shots pano if I need a wider shot. What do you think?
Ps: I'm using a K-1 body
09-07-2016, 07:58 AM   #2
baro-nite's Avatar
That lens (on the K-1) is a close match for the fields of view I most often use for landscapes (wide to short tele), so it sounds like an excellent choice to me. Some prefer something wider. As you say, you can always stitch when needed.
09-07-2016, 08:02 AM   #3
amateur dirt farmer
pepperberry farm's Avatar
one lens - sounds like a job for the DA18-135mm...
09-07-2016, 08:06 AM   #4
MJKoski's Avatar
For Pentax landscape it would be Leitax (or native) converted 35/2 Zeiss Distagon. I would complement it with 21mm Distagon and 50/1.4 planar. For UWA, 15mm Irix.
09-07-2016, 08:06 AM   #5
QuoteOriginally posted by pepperberry farm Quote
Does it support FF image circle?
---------- Post added 09-07-16 at 08:08 AM ----------
QuoteOriginally posted by MJKoski Quote
Sounds like a pretty expensive (albeit awesome) combo) plus all manual right?
09-07-2016, 08:15 AM   #6
QuoteOriginally posted by awscreo Quote
...I'm leaning towards 24-70 2.8 as it seems it'll give me a lot of flexibility on hikes and travels...
Consider the 28-105 because it's less weight to carry around. Most landscapes are stopped down anyway, making the f2.8 less essential. You'll unfortunately lose 4mm at the wide end.
09-07-2016, 08:20 AM   #7
QuoteOriginally posted by DeadJohn Quote
I am considering it as well. Seems like a very nicely priced and capable lens. But I'm not sure if maybe a 2.8 zoom would be nice to take as a single lens setup if I'm travelling, so I can take a portrait of my wife if I wanted. Although maybe I can use a separate prime for that (although it seems most of portraits primes for k mount are pretty pricey, wish we had a nice affordable 85 1.8).
09-07-2016, 08:22 AM   #8
amateur dirt farmer
no idea - it is a DA lens, so not officially a FF lens...
but that wasn't in your question (FF vs APS-C):
What would it be?
09-07-2016, 08:25 AM   #9
Failed to mention that, thought my signature would be enough to see what body I'm using.
09-07-2016, 08:28 AM   #10
amateur dirt farmer
agreed - if signatures were shown on my screen.... good luck in your search!
09-07-2016, 08:35 AM   #11
Updated the post) thanks for the tip, I just noticed sigs don't show in the mobile version of the forum.
09-07-2016, 08:39 AM   #12
Na Horuk's Avatar
The DFA 24-70mm seems like a great lens, but it is not really very wide by modern standards. Something like DFA 15-30mm might be better suited for ultra wide and it would still give you a comfortable zoom range.
That said, I prefer primes. If budget was no issue, I would look into Zeiss ZK in the range between 20mm to 28mm. Never had a western, modern Zeiss lens, but they seem to be pretty good Since budget usually is an issue, I would look into Samyang 14mm (have it, love it, FF lens, but I use it on APSC) or Samyang 24mm. Or better yet, wait for the new Samyang 20mm to be released.
Unfortunately, Pentax is currently missing Wide angle primes. The widest you can find is the superb FA 31mm ltd, and it may be wide enough for many things. I would prefer to go with 28mm (like F 28mm f2.8) or wider, because I usually shoot wide angle.
Just my tips, subjective as they might be. You can check my gallery (sig) to see which primes I use for what kind of photos, but even though all my primes are FF, I use APSC camera
09-07-2016, 08:49 AM - 1 Like   #13
Thanks for suggestions! I also prefer primes, in fact this is the first time I consider getting a zoom. Samyang was a natural first choice as well. The reason I was looking at the 2.8 zoom is a) never owned a fast pro zoom b) thought it might be a good one lens setup for most things c) all of my wide lenses before were MF, and I'm leaning towards having more AF gear at this point (already have 5 legacy manual primes).
Before I was doing just fine switching primes on the go, plus weight was never an issue with my previous system (MFT), not sure how I'll feel carrying around 4 pounds of glass and metal on me all the time lol.
09-07-2016, 09:20 AM   #14
emalvick's Avatar
I think the 24-70 sounds like a winner. With my K3 I liked my Tamron 17-50 as my landscape lens for years. For full frame, you'll find the 24-70 is about the same.
Stitching for wider shots is good unless you or often finding yourself wanting to shoot wider; then it's a drag. These days I like using the 21 mm and 31 mm for landscapes. On a full frame, I'd probably try to use the 31 mm as much as possible. I try with my K-3 although it's a bit tough for wider landscapes. I can't recall if the 20-40 mm that's out is FF compatible, but that could be a good landscape lens with the caveat that you lose almost any telephoto capability.
09-07-2016, 09:30 AM   #15
les3547's Avatar
RE primes, I'm curious why more people didn't recommend the FA 31 LTD. Photographers shoot landscape with all sorts of focal lengths, not just ultra wide (which often also means plenty of distortion). The FA 31 is wide angle, virtually free of distortion, low CA, pretty fast at f1.8 (by f/2.8 resolution is high and vignetting is tamed), beautifully built, and at 345g is about as portable as a great lens gets. Also, sub-24mm primes are on the way (Samyang 20 and Irix 15 for sure, Pentax almost certainly). Me, I'm hoping for a compact Limited-quality 24mm from Pentax.
database, distagon, dpr, examples, k-1, k-mount, landscapes, lens, lenses, mm, pentax, pentax lens, pf, photo, portraits, post, slr lens, tamron, thread
If you had to choose one filter for one lens... Jeff Pentax Camera and Field Accessories 16 06-24-2016 10:39 AM
If you had to choose one lens lextextrapper Pentax SLR Lens Discussion 86 04-10-2015 02:03 PM
If you were to give one piece of advice to a complete beginner? ThueO Troubleshooting and Beginner Help 57 07-01-2013 12:02 PM
If I were to shoot slides... Sagitta Film Processing, Scanning, and Darkroom 15 05-25-2013 05:57 AM
If you HAD to use ONE lens to shoot a wedding... ashamsuddin Pentax SLR Lens Discussion 50 12-06-2008 09:39 AM
All times are GMT -7. The time now is 05:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
