Originally posted by stevebrot Apparently you haven't gotten the word. The 35mm FF format (e.g. Pentax K-1) is the same size as 35mm film and the 28mm focal length that never fit in with APS-C is a very different tool when given a little breathing room. You may feel that 24mm "now rules the roost" and you are welcome to your opinion, but I will pit my 45+ years practical experience shooting 35mm format with a variety of lenses against that opinion. The 24mm focal length has its uses, but it was a niche market back in the day mostly because it is a tough fit to subject in much the same way as the DA 15/4 Limited on APS-C.
Don't worry, I had noticed that Pentax has joined the digital FF world - but thanks for the assist. Thing is, my opinion is based on what is happening in the rest of the digital FF world - and 24mm really has taken over the space previous occupied by 28mm lenses. 24mm is the normal wide angle of the modern era - this isn't a Pentax thing, it isn't a me thing, it isn't a pretty-much-everyone-else-in-the-thread thing, it is a digital photography thing. By the same token we have seen the rise of the UWA, from a rare oddity in the film days to commonplace in digital.
Feel free to shoot like its 1979, there isn't exactly a lack of good 28mm legacy options if you find 24mm just a too wide for your tastes and too troublesome to crop. I suspect that Ricoh, however, will be basing their development choices on more business orientated reasoning, and in that the prevailing market trends (ie. looking at the existing players, the pragmatic approach) will rate far more than what worked 20+ years ago - this is exactly what would have driven them to prioritise the 'holy trinity' of f2.8 zooms, which was not exactly a hark back to the 135 film glory days.
From that business perspective there might be a case for refreshing the FA 28/2.8 as a quick, budget option to flesh out the lineup. But I don't think it is that simple. I suspect much, if not all, the production line machinery for the discontinued FA lenses is long destroyed, making the costs of gearing up a new run of these old lenses not much cheaper then making modern designs and putting them in production. That said, if a budget refresh was on the cards the FA 20-35mm would likely be the better choice for Ricoh. That the old FA lenses haven't returned en masse is probably for the best, the Pentax brand doesn't need to be panned as being 'outdated' by the usual sources, a legacy of the film era treading water to survive. Ricoh needs to establish Pentax as a brand of top-notch, modern optics that match the capabilities of the K-1.
By the by, neither 28mm or 24mm give a wide angle FOV on APS-C (by the technical definition 24mm winds up
just on the normal side of the divide). But the same phenomenon which has gripped FF digital photography (wider going wider then was common in the film era) has also gripped the smaller format, with 18mm (the close equivalent of 28mm) being the domain of kit lenses and consumer super zooms. More 'serious' (read, expensive), higher end lenses come in at around 16mm (equivalent to 24mm). There is also a distinct lack of 18mm primes everywhere, every manufacturer seems to be pushing wider.
---------- Post added 09-10-16 at 11:39 PM ----------
Originally posted by jatrax What logic would that be exactly? Those are both rather exotic lenses, more suited to enthusiasts with time to experiment than to the professional market, IMHO. As already asked above I am curious what type of photography requires 24mm f/1.4? The only reply I've seen is wide scale astrophotography and even that is debatable.
The IQ gap between zooms and primes has narrowed considerably, lens engineers are cranking out ridiculously good designs for zooms and the phase 'bag of primes' is entering overused territory. With one of the major advantages of primes over zooms nearly eliminated, that leaves aperture, size, and for some, cost. So I can see the reasoning, a 24/1.4 is two stops faster than the DFA 15-30mm. That said, such a prime would be massive and expensive, and an extra stop over f2.0 would be an advantage in a pretty limited number of uses (in doors with natural light being the main one I can think of - contrary to popular belief, speed isn't everything for astrophotography).
f2.0 is probably the best we will get out of a DFA* wide angle prime as it'll allow size and cost to be kept reasonable - you are right that something faster is likely to be an exotic item with limited appeal, especially as any WA lens bought for landscape use will not be used wide open often. Better for Ricoh to invest their limited resources in new Pentax lenses that will sell.
On the point of astrophotography, super fast lenses tend to exhibit way too much aberration to be truly desirable - chroma and coma are killers in this art. Fast, wide lenses that don't have to be stopped down are a real rarity. Even of the current masters of this domain, the Samyang 24/1.4 and 14/2.8 you have to make sacrifices - in the case of the 24mm, it has noticeable coma on FF, which doesn't really come under control until you have moved past f2.8 (which means that extra few stops of aperture are wasted) - luckily it is not as problematic on APS-C, but then you lose a chunk of your FOV. For the 14/2.8, well, it is f2.8, 2 stops slower than a f1.4 lens anyway - for that you get pretty much the best coma handling out there, and minimal chromatic aberration as a bonus. I would hate to think what a 14/1.4 with similar optical quality would look like (or cost, for that matter), but given how good the 14/2.8 is for astrophotography there isn't much demand for a faster model anyway. For astrophotography a f2.8 wide angle lens is plenty fast, so long as it has an optical formulae that is up to snuff.
