Originally posted by Jmhsnk
Yea, it's clickless. Not the best thing, but the best that's out there.
Since this is not an electronic interface it only makes sense that these are clickless - they simply put pressure on the lever and slowly close the diaphragm. If you want to get a little more clarity you could dedicate adapters to various lenses (they are cheap) and mark them in paint or with an engraving tool with your f/stops. You can calculate the f/stops by starting with a wide open metering with a constant light source. Then you can slowly stop down until the shutter speed changes in Av mode. You then mark the change as appropriate. So if you start with 1/500 at f/2.8 and you get to 1/250 you mark that point as f/4. You then continue stopping down and at 1/125th you mark f/5.6, etc. Then you mark that adapter as specific for that lens. In theory it would be good as marked for any lens that has the same starting f/stop* but I haven't tried that. I have only used tape to mark a single f/stop for a day myself but the idea is workable as described.
*The lever motion relative to f/stop changed from M to A series but all mechanical aperture linked lenses with aperture irises that do not have aperture rings that I know about are FA-J, DA or DFA which all use the same lever motion.
