09-12-2016, 05:04 AM   #1
Pentax 1.4x DA-HD Extender
I bought one 'New' from Japan through Ebay. It looks new. Mechanically and electronically, it works perfectly.
But the image quality is terrible, especially near the edges. Atrocious with the 50/1.8DA. Really bad with the 70/2.4 DA. Ok but not great with the 100/2.8M D-FA. Good with the 200/2.8 FA*.
Is it 'normal' or do I have a 'lemon' ?
09-12-2016, 05:20 AM   #2
Senior Moderator
BigMackCam's Avatar
That doesn't sound right at all. Do you have a couple of images you could post from the 50/1.8 and 70/2.4? I primarily use mine with the DA*60-250, and I find it works well at all focal lengths. I've also tried it with the DFA100 and was very happy with the results. There is a *slight* reduction in IQ, for sure, but very minor indeed...
09-12-2016, 05:41 AM - 1 Like   #3
Emperor and Senpai
VoiceOfReason's Avatar
What camera are you using it with? With the K1, yep, that's normal since it doesn't cover FF, with any of the APSC cameras you should have good edge to edge quality.
09-12-2016, 06:00 AM - 1 Like   #4
pjv
Otis Memorial Pentaxian
pjv's Avatar
QuoteOriginally posted by Belgarchi Quote
Hi Belgarchi. I see from your profile that the 2 cameras you list are the Kx and the K10D. The converter will not work properly on the K10D because there is no firmware update to " marry " the converter to it. As far as the Kx goes, check your firmware status and see if you have the latest version. Good luck.
HD Pentax-DA 1.4x AW AF Rear Converter Reviews - DA Teleconverters - Pentax Lens Reviews & Lens Database
09-12-2016, 06:06 AM   #5
Senior Moderator
BigMackCam's Avatar
QuoteOriginally posted by pjv Quote
Well picked up, Peter - I hadn't thought of that!!
09-12-2016, 06:11 AM   #6
pjv
pjv's Avatar
Thanks Mike. In the good old days ( film ) any attachment put on the camera would work because they were all manual. These days because of the technology, unless they can " talk " to each other electronically, they just won't work properly, if at all.
09-12-2016, 06:28 AM   #7
Pentax K70
I am using it with a Pentax K30 and a K70.
Will take test photos later today and post them.
09-12-2016, 06:44 AM   #8
UncleVanya's Avatar
I would think the SR would be set incorrectly, but that would be the only real issue unless the person is using in camera jpg lens corrections. Trying a shot or Two without sr on might be helpful.
09-12-2016, 06:56 AM   #9
pjv
pjv's Avatar
Thanks for that info UV.
09-12-2016, 06:59 AM   #10
UncleVanya's Avatar
Specifically for the k10d I meant to clarify. Let us know if that helps.
09-12-2016, 01:55 PM   #11
Test with Pentax 1.4x DA-HD
I have problems to upload the photos, not enough space.....
I took a brick wall with the extender 1.4x +
1. Pentax DA 50/1.8 at 1.8
2. Pentax DA 50/1.8 at 2.8
3. Pentax D-FA 100/2.8M at 2.8
4. Pentax D-FA 100/2.8M at 4.0
5. Pentax FA* 200/2.8 at 2.8
The results are:
1. Everything is blurry, especially the edges
2. The center area is sharp, the edges blurry. Huge improvement.
3. Except for the corners, everything is sharp
4. Like 3, very slightly better (the corners are still not perfect)
5. Like 3, center very slightly less good, corners very slightly better
In a nutshell, not usable with the 50/1.8 (except maybe at 4.0 or more?), good but not great with the 100/2.8M and the 200/2.8.
09-12-2016, 02:29 PM   #12
boriscleto's Avatar
Create an account on a photo sharing site, then share the photos here using a BBCode link.
http://www.flickr.com/
Photo and image hosting, free photo galleries, photo editing
https://picoolio.net
k-mount, pentax 1.4x da-hd, pentax lens, slr lens
For Sale - Sold: Pentax K3/D-BG5 - HD-DA 1,4x AW - Kenko 1.5x Wosp Sold Items 7 07-31-2016 01:07 AM
K-1 and the HD PENTAX-DA AF REAR CONVERTER 1.4X AW SteveD Pentax K-1 9 06-26-2016 06:42 PM
DA 300* with HD Pentax-DA AF Rear Converter 1.4x AW SashasMom Pentax SLR Lens Discussion 17 12-06-2015 01:08 AM
Pentax HD DA AW 1.4x converter $399 photolady95 Pentax Price Watch 8 07-31-2015 01:48 PM
For Sale - Sold: Pentax DA HD AF Rear Converter 1.4x AW Mikesul Sold Items 3 01-12-2015 08:56 AM
All times are GMT -7. The time now is 01:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
