09-16-2016, 05:51 PM   #1
Samyang 35mm f/1.4 Focus Adjustment
Hello all...
+8 focus adjustment. Seems a bit much for a new and fairly modern lens. Is this weird? Has anyone else needed such an adjustment for your new lenses?
Most of my lenses are used K and M beauties, so I'm a bit outta water here. Thanx!
09-16-2016, 06:04 PM   #2
Closed Account
QuoteOriginally posted by strangeboy Quote
Hi strangeboy. As the lens is manual focus ( I think from the specs ), the AF ( auto focus ) adjustment feature does not apply.
09-16-2016, 06:05 PM   #3
MJKoski's Avatar
How do you adjust AF for MF lens? Samyang 35mm has been full manual so far.
09-16-2016, 06:10 PM   #4
Yes. You can set the focus adjustment for manual lenses using the "AF Fine Adjustment: Apply All".
Check your manuals, folks.
09-16-2016, 06:36 PM   #5
Closed Account
" Apply All " means the same value is put on all AF lenses mounted on the camera, not all lenses. Manual focus lenses cannot be adjusted.
09-16-2016, 06:46 PM   #6
QuoteOriginally posted by pjv Quote
Apply all is the only way to adjust manual lenses. I have done this for a couple mine: Porst 55mm f/1.2 which requires a -4, and the K 50mm f/1.4 at -2. There are a number of threads here that discuss this.
---------- Post added 09-16-16 at 08:50 PM ----------
There is no chip in these lenses that the camera can read, which is why you must use Apply All.
---------- Post added 09-16-16 at 09:03 PM ----------
Here is one discussion: https://www.pentaxforums.com/forums/115-pentax-k-5/171047-focus-confirmation-manual-lenses.html
---------- Post added 09-16-16 at 09:12 PM ----------
Manual lenses (i.e. lenses that the camera doesn't recognize) will need to use the global adjustment (Apply All) rather than a lens-specific adjustment (Apply One).
Read more at: Fixing Front and Back Focus - The Remedy - In-Depth Articles
---------- Post added 09-16-16 at 09:14 PM ----------
Now... back to the OP.
Has anyone with reasonably new manual focus lenses ever had to make such large adjustments? Is this normal?
Thanks, again!
09-16-2016, 07:21 PM   #7
UncleVanya's Avatar
Mount and lens tolerances are not perfect and with modern sensor resolutions it is easy to have a lens / camera mount combo that needs a large value. That same lens may be a 0 or a minus 7 or a plus 1 on another camera body.
09-16-2016, 07:24 PM   #8
Manual Focus Lens Adjustment
QuoteOriginally posted by MJKoski Quote
AF is something of a misnomer, since you can also compensate for manual focus lenses. You can make adjustments for Manual Focus lenses using the "Apply All" feature. This will move the focus either forward or backward. Unlike Autofocus lenses, the camera will not remember to which lens this adjustment should be applied, that is up to you. The thing I had to remember was to turn it off when attaching a different lens.
---------- Post added 09-16-16 at 09:26 PM ----------
Thanks... Just wondering what others have experienced.
09-16-2016, 07:31 PM   #9
UncleVanya's Avatar
Gotcha. The only Samyang I have is the 8mm fisheye and honestly I don't even really try to focus it. I just use f/8 at hyper focal most of the time.
09-16-2016, 09:17 PM - 1 Like   #10
This. AF confirmation has so much tolerance that applying fine adjustments is moot for MF lenses.
Use focus peaking or LV magnification instead
09-16-2016, 09:28 PM   #11
Not my experience. I often shoot at f/1.2 and f/1.4. I also use a Katzeye Focusing screen. These adjustments make a difference for me and a number of other shooters.
09-17-2016, 12:59 AM   #12
Can be, af tuning is taken into account for focus confirmation in the viewfinder; but it can be that there is a certain amount in random error from the focusing confirmation range itself. The +8 adjustment may not be the best value. I'd shot a multiple shots with each adjustment value and later on select the adjustment value that provide the best set of images. It is possible that +8 adjustment is required for your Samyang, but I wouldn't be worried so much. Canon adjustment range is wider, e.g +-20um range. You can have up to +10 or -10 adjustment on the Pentax camera, it does not mean the lens is defective, it's fine.
09-17-2016, 11:05 PM   #13
Thanx, biz. That's the info I was looking for. This lens is a departure for me since I shoot overwhelmingly with my beloved K lenses. I have a K 35mm f/3.5 arriving any day now, but I'd read such good stuff about the Samyang, that I bought it just to try it out. I'm not sure if it's a keeper yet.
So far it seems very useful wide open, f/1.4. I'll see how it stacks up to the legendary K 35 in a few days.
Thanks again.
35mm f/1.4 focus, 50mm, 55mm, adjustment, af, af lenses, bit, camera, couple, f/1.2, f/1.4, focus, focus lens, k-mount, lens, lenses, mine, pentax lens, pm, post, samyang 35mm f/1.4, slr lens, threads
Samyang 35mm f/1.4 AS UMC Sagitta Lens Sample Photo Archive 11 10-12-2023 11:46 AM
Rokinon 24mm f/1.4, Samyang 24mm f/1.4, HD DA 21mm f/3.2 or Sigma 18-35mm f/1.8? saka Pentax SLR Lens Discussion 5 01-28-2016 06:22 PM
K5 + Samyang 85/1.4 Impossible to find focus at f/1.4 Focusing aid needed? minahasa Troubleshooting and Beginner Help 6 04-13-2014 07:06 PM
For Sale - Sold: Primes: Samyang 35mm f/1.4 Manual Focus, Vivtar 135mm f/2.8 M42, Revunon 55mm f/1.2 takhyon Sold Items 9 03-16-2014 08:42 PM
All times are GMT -7. The time now is 04:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
