09-19-2016, 05:08 AM   #1
photoramone's Avatar
60-250mm tele by pentax does not want to auto-focus
Anyone else have/had this problem? What was your SOLUTION???
09-19-2016, 05:36 AM   #2
Hogdriver's Avatar
For what its worth...
Lens in "Auto" position? Check and clean contacts on lens and camera? Worse case could be SDM failure...a rarity for the 60-250 lens. Ability to test lens on another Pentax camera body?
Hope it is only something simple...
09-19-2016, 06:46 AM   #3
Otis Memorial Pentaxian
not rare...i had one go out a few months ago..sounds like sdm
09-19-2016, 08:26 AM   #4
UncleVanya's Avatar
Sadly no one has figured out a workable screwdrive conversion for this lens.
09-19-2016, 12:51 PM   #5
bdery's Avatar
Is the switch on the lens set to MF? It gave me a scare once, mine had been move accidentally.
09-19-2016, 12:55 PM   #6
UncleVanya's Avatar
I've been there too. In my case it looked like AF was set but carefully moving it it was clearly not all the way to AF.
09-19-2016, 01:43 PM   #7
Thanks to all respondents. I will try those things. Everyone wants about $300.00 to repair it RJM
---------- Post added 09-19-16 at 01:45 PM ----------
Bye-the-way, what do you folks recommend as technique to clean the camera and lens CONTACTS. Fluid of ANY kind???
09-20-2016, 11:57 AM   #8
QuoteOriginally posted by photoramone Quote
I have my K3-II set to use the AF button on the back.
I press and release it quickly about a dozen times - never waiting for it to actually try to focus.
Between 1-2 dozen presses it "wakes" up and works.
I have to do this every time I use the lens (used rarely and sits on the shelf a lot).
60-250mm tele, k-mount, pentax lens, slr lens, tele by pentax
60-250mm/f4 to cover all needs between 100-250mm?? Opinions/advice welcome gda13 Pentax SLR Lens Discussion 34 08-17-2016 06:01 PM
Newbie question: does the metal ring on 60-250mm lens come off? redridinghood Pentax SLR Lens Discussion 4 12-02-2015 04:58 AM
Shooting on Auto: does aperture need to be set to auto? heyjoe Welcomes and Introductions 2 05-27-2015 01:32 PM
Pentax DA* 60-250mm not focusing jbrowning Pentax SLR Lens Discussion 8 06-30-2014 02:00 PM
Pentax 18-135mm does not focus to infinity below 33mm bwDraco Pentax SLR Lens Discussion 9 07-29-2013 12:00 PM
All times are GMT -7. The time now is 07:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
