09-19-2016, 07:52 PM   #16
arnold's Avatar
I tried P.S. on a tripod, 2 sec delay and DNG. with an M200mm. The results were worse than another plain JPEG straight from the camera, which was taken at the same time. I have a simple Elements 8 PP program, so I wonder if it has trouble with Pixel shift. The PS jpeg was not much better straight out camera.
09-19-2016, 08:34 PM   #17
QuoteOriginally posted by MJSfoto1956 Quote
I can report that the combination of pixel shift + post processing in piccure+ will give you images that will simply blow you (and your clients) away. You can try piccure+ for free for 30 days. Warning: it is slow as all get out. But I find the processing worth doing for all my "keepers".
YMMV
Michael
I second that! Piccure is pretty amazing, yet CPU intensive at high quality settings.
09-19-2016, 08:48 PM   #18
Otis Memorial Pentaxian
QuoteOriginally posted by arnold Quote
Are you sure that Elements 8 supports merge processing for pixel shift DNG? I suspect not. In that case Elements will extract bundled exposure #1 and process that image.
09-19-2016, 08:54 PM   #19
rechmbrs's Avatar
PSR
You must use either Pentax DCU 5.6.1 or Adobe ACR 9.6.1 to properly composite the DNG file. Elements won't do it. What camera?
RONC
09-19-2016, 09:52 PM   #20
arnold's Avatar
QuoteOriginally posted by rechmbrs Quote
RONC
Pentax K1. The Pentax software is not user friendly, and I don't know what ACR 9.6.1 refers to. Seems my suspicions were right. Elements 8 can't handle DNG pixel shift. The camera JPEG pixel shift was not as good as a standard JPEG, but maybe that is also an Elements 8 problem.
09-19-2016, 10:52 PM   #21
rechmbrs's Avatar
ACR is Adobe Camera Raw which is part of Photoshop or Lightroom.
I think the jpg should be processed by Elements ok but you must back off some on sharpening.
I can run ACR on the DNG if you would like and pass a file back to you if you wish. Send me a PM with a Dropbox or other storage location for the file.
RONC
09-19-2016, 11:12 PM   #22
arnold's Avatar
RONC
Thanks for the offer. I still don't know why the pix shift jpg from the camera was worse than the plain jpg. I will put the DNG on Flicker.and post the link here with an edit, for all to see. Look forward to see what comes out.
Edit: Flicker doesn't do DNG. Here is a Google link that took 25 minutes to load!!
https://drive.google.com/open?id=0BzHQJ3JAJyxEWlowZGU5MU9vOUE
Here is a normal JPG of the scene for comparison, with only levels and sharpness adjusted.
Hill about 7 miles distant. A70-210 used
09-19-2016, 11:37 PM   #23
rechmbrs's Avatar
You could put the jpg up also.
RONC
09-20-2016, 12:18 AM   #24
MJKoski's Avatar
Using 200mm lens with PS requires insanely stable setup. Even slight wind can mess up the exposure. Much more so with short exposure times.
09-20-2016, 01:42 AM   #25
arnold's Avatar
RONC
All true, and I did use a stable tripod with the 2 second delay. Clearly Pix S. is not for casual use.
This is the DNG JPEG
[IMG][/IMG]
[/url][/IMG]
09-20-2016, 03:14 AM   #26
rechmbrs's Avatar
[/url][/IMG]
[/url][/IMG]
I'm waiting on your response to Google for me to get the DNG.
JPG difference seems to me to be haze on PSR which your levels might have fixed on other if it were there.
RONC
09-20-2016, 04:40 AM   #27
arnold's Avatar
RONC
IMGP0615.DNG - Google Drive
https://drive.google.com/file/d/0BzHQJ3JAJyxEWlowZGU5MU9vOUE/view?usp=sharing
This is the sharing link. Don't know what else I can do.
The jpeg off the DNG could not be brought to the standard of the first plain shot. The JPEG engine seems hard to beat.
09-20-2016, 05:24 AM   #28
rechmbrs's Avatar
I just finished the download.
I think you will be surprised.
RONC
09-20-2016, 01:00 PM   #29
rechmbrs's Avatar
Excellent example of Pixel Shift Resolution mode's GOTCHAs
Arnold,
After reviewing the DNG file and the Pixel Shift Resolution output - with and without Motion Compensation - I find that this exhibits motion of all sorts and is not usable in PSR. There is vehicle motion which is pretty well handled my the motion compensation. There is foilage motion that I feel is not a great problem and finally there is a very large amount of camera movement. The camera motion happens to a large extent between the shots and there is lateral, rotational and vertical motion. In truth the motion resembles my attempts at hand holding the camera for PSR but wind blowing the camera or movement around the camera by vehicles or people is enough to cause what is exhibited.
When PSR happens in the K-1, the sensor moves only about 0.0002 inch or 5 microns per pixel shift. How much wind abeam to the camera and lens is necessary to move/rotate the setup? Not much I'm afraid.
Your comments earlier are correct that PSR is finicky. But if you knew what you know now about the method would you attack the problems differently? Might you use your vehicle, not running, as a wind break? Was it a tripod setup to do most to dampen induced motion? Different tripod? These are the the same things we think about with long exposure shooting.
Pixel Shift is not magic!
RONC
09-20-2016, 01:29 PM   #30
MJKoski's Avatar
Use ND filters to bring up exposure times. I found it works very nicely in bad conditions. But still I always keep my tripod low when doing PS work. It weights about 5kg plus ballhead (Benro B-4).
Short exposure times are most critical with PS.
Always use 2sec timer to start the exposure. Preferably with remote.
35mm, art, clients, combination, corners, days, delay, dozens, edges, exposure, f/5.6, f/8, images, k-mount, k1, lens, lenses, michael, pentax lens, post, ps, sigma, slr lens, sort, tripod, ymmv, zeiss
Advancing the Ball: Review of "Pixel Shift" in Different Software Michaelina2 Digital Processing, Software, and Printing 5 06-18-2016 08:43 AM
What's "pixel shift motion correction function"? Fenwoodian Pentax K-1 & K-1 II 36 02-27-2016 09:55 AM
Why are T&S lenses so expensive and "special"? ytterbium Pentax SLR Lens Discussion 8 08-14-2011 08:47 PM
Are "3rd party" lenses as fast at focusing? slip Pentax SLR Lens Discussion 2 11-23-2006 05:05 PM
All times are GMT -7. The time now is 02:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
