Originally posted by THoog Was it a lens that had been produced for K-mount? I know some folks were trying to get K-mount versions of lenses that were never produced in K-mount - Sigma doesn't have the parts to do that.
The Sigma SA-mount is all-electronic, and in fact uses the Canon EOS signal protocols for communication. All the MC-11 converter has to do is translate the Sony E-mount signals to/from the SA/EF-mount lens. For K-mount lenses, it would have to include a motor and linkages for aperture control. Unless you mean to mount Sigma SA/EF lenses on Pentax, which is an entirely different problem - even if they can now translate the signals to/from KAF4, the flange distance is too short, and would require corrective optics, reducing image quality.
First part answer: Yes it was otherwise i wouldn't have sent it in. Don't worry i checked first.
Second part answer: Debatable considering that i am using the sigma 18-35 f1.8 art on Pentax which isn't any less impressive than the MC-11 compatible lens models. Then you also have full manual mode which is odd because you have rokinon or samyag manual lenses that work just fine on Pentax. However still no way use SA mount on pentax in full or partial manual mode which is odd when you can still use 1970's lenses. If you follow, and if not i guess the easiest way to explain it to have the ability to use most of the adapted lens abilities and the rest you do yourself. Even now i have to micro adjust my K-1 or K-3 as the AF is always a little bit off and for things like portraits or landscapes i still manual focus. If i can get the lens good optics and minimal function i can't really complain, do the USB lens calibration once out of camera and that's it.
You are correct if you want the fast sports oriented functions of the lens and that is also evident with the latest Fuji and Panasonic cameras as well. I have 4 different camera brands which is kind of silly and all because of the lenses. Which is more than a little expensive especially in Canada. I can't even get the Sigma 150-600 f5.6 telephoto wildlife lens for pentax and it's not a fancy model either. Pentax itself doesn't have anything other than 150-450mm and from what i have seen the Sigma lens is sharper but the Pentax has better colour rendition. Just basic functions is all i need. Also just how much electronic AF refinement are you going to get out of a prime lens with only a few elements at best.
If i want the full features of my SA mount sigma lenses i stick them on my SD-1, problem solved. Performance wise there isn't any difference between the 18-35 f1.8 pentax k-mount and the 18-35 SA mount. Both cameras & lenses articulated at exactly the same rate.
No matter. Thanks for the input, i appreciated it.
