Thanks again for your valuable comments! I appreciate them.
Maybe one advantage of a walk around lens like the 28-105 is, that you are more or less forced to use the K-1 as an interchangeable lens system again... Having it equipped with the 24-70mm 2.8, I found myself too lazy in the end for changing lenses because you could, after shooting architecture and landscape, also make a decent portrait with it... this might now change so that in the end I'll be using my FA77 or FA43 more often which might end up in better quality.
While travelling I actually used my 24-70mm as a versitle lens, almost like a "superzoom" just without the (wide) zoom
. Or I didn't use it at all because it's was inconvenient due to its size/weight.
Well, the 28-105 might change bad habits! (hopefully)
So if one looks at it this way...
