Hi jmdeegan
Re your present dilemma:
Quote: a-18-250, 10-20 and 10-17
I hope you don't mind me asking, but unless you're possibly worried about encountering problematic low-light situations, I'm slightly puzzled WHY you feel the need to take BOTH the 10-20 and 10-17 along with you ?
As for DJey's comment:
Quote: Which do you prefer? IQ or Comfort?
Well actually both if possible ! Quite frankly, I have come to the point where I am getting thoroughly sick to the back teeth hearing from ill-informed individuals that often don't even own an item, who subsequently decide to start denigrating it by expressing critical remarks with precious little justification.
FWIW I have been fortunate to work my way up from 35mm film SLR's through MF up to 5" x 4" technical cameras and if I believed
for one moment that the Tamron 18-250mm was not up to scratch, I'd be the first to admit it !
There IS slight barrel distortion at the wide-end which is totally subject dependent and slight pin-cushion at the other. So what....BIG DEAL ! Have you never heard of PP images before? If you think it's possible to design such an amazing lens as this one without encountering a certain degree of compromise, then you're sadly mistaken !!
Despite this however, IMHO for the most part the 18-250mm remains an incredibly flexible and optically sharp lens and I'd have no hesitation WHATSOEVER recommending it to anyone on the lookout for a decent walk-around zoom. If you prefer to cart tons of gear around with you all the time, then naturally that's your prerogative, but when I travel nowadays I prefer to do so as lightly as possible and with the Sigma 10-20mm permanently attached to my other K10D body, I couldn't be happier !
Best regards
Richard
