Not sure if is just me but I am totally perplexed by this issue of Front/back focus. I am not suggesting that the phenomenon does not exist but I wonder sometimes how important it is. I base my scepticism on several totally unscientific observations I have made from reading several recent posts on the subject.
The majority of complaints arise from photos that are often:
- taken in poor light. (High ISO and Low Shutter Speeds)
- hand held. (Photographers move up, down, front, back and sideways)
- taken of subjects that move. (People and Pets)
- taken at the widest aperture of the lens in question. (f1.4 - f2.8 seems to cause the most problems. Shallowest possible DoF. Not the sharpest aperture for most lenses)
- taken at or near the minimum focusing distance of the lens in question. (Shallowest possible DoF)
- that have a multitude of perfectly legitimate points of possible focus. (Wide angles in a darkened auditorium with multiple actors on stage. How is the camera supposed to decide which eye or whose nose to focus on?)
Other factors that may or may not affect results.
- Cameras do take a certain time to activate the auto-focus mechanism.
- Is the setting to prevent shutter release without focus lock activated?
- Is the camera set to AF.S or AF.C?
- Is the photographer using the Back Button system?
- Is SR turned on and given time to do its thing?
- Is zone or single point focusing applied?
Sometimes I think many of us are too ready to condemn our cameras without properly considering technique. As several have already pointed out, any adjustments should be conducted in a highly controlled manner after very careful testing and evaluation and not on the basis of a few apparently out of focus images.
I am not perfect, nor are my cameras or lenses but there are a few techniques to achieve better focus.
- Use a shutter speed appropriate to the subject and the focal length of the lens.
- Use an aperture appropriate to the subject and required depth of field.
- Let the camera worry about ISO and deal with any noise in PP. TaV mode is the way to go. On flowers I prefer TaV mode at f11 and 1/250th of a second. ISO whatever.
- Avoid wide open unless you have a need for narrow depth of field.
- Avoid auto focus in macro work or in poor lighting.
- Use back button focusing with AF.C
- Use burst mode. Often the second or third shot is sharper.
- Use tripod, remote control or timer and MUP if appropriate.
I have downloaded and printed test patterns to enable me to check for front/back focus. It is just I have yet to feel the need to check and adjust. Yes I do get many out of focus images. Most of them if not all, I put down to poor technique.
