Originally posted by hadi Is that normal? Did i get a lemon?
Um, what? Do you think it can happen that somehow a lens gets a wrong LENS ELEMENT? Come on. Its possible that a lens element is slightly misaligned, by a matter of milimeters. but there is no way they would just give you a straight up wrong lens piece lol The only "problem" would be if you accidentally bought/received a Samyang 16mm (which is a crop-only lens). Just read the labels on the box and lens. The size of the back element can indicate the format (APSC, FF, MF), but it is not a definitive rule. It depends on the lens design
Anyway, I recommend you post sample photos.
The Sigma at 10mm on APSC is almost as wide as the 14mm on FF. Nothing unusual there, since the "crop factor" is around 1.5. But the Samyang will give you better aperture (lets you get more shallow DoF, more light) and sharper image. My Samyang 14mm is really sharp at f2.8 already, and stays amazing up to f10 or so, but I only have APSC camera.
Originally posted by hadi Now, mind you, ive only had the lens for 1 day...
I think its just this
Its first day nervousness, happens with any major purchase. Use the lens, take photos, have fun. After a couple days, after some comparisons, then tell us how things go. Post some sample photos if you want.
Just push the little button on the aperture ring and lock the ring into A mode. This will give you lots of automation on the camera, so you can use P or Av mode. Next, learn how to focus. I had quite a bit of difficulty with this at first, but then I learned the distance scales are miscalibrated. There are some posts and youtube videos about how to calibrate it yourself. I didn't bother with that, I just learned at which number I can get hyperfocal focusing at f8.
I'm sure you will enjoy the lens, just give it some time.
