Originally posted by Shock2DC There is some light in the small pen, but the larger one, unless she is close to the barn, there isn't much. I attached small pen pics from Monday. Utilizing a tripod, I did try the prefocus idea on Monday, but the results were not good. Perhaps my ISO or shutter speed were insufficient. That is where I am disconnecting. I don't understand how they work together. SO much of what is out there on youtube is geared towards techies, and, in relation to photography, a techie I am NOT.
ISO is basically like volume control except for light. Big numbers are turning up the slight sensitivity of the sensor. Eventually you run into practical limits, the equivalent of a radio that's too loud. The scale is usually 100, 200, 400, 800, 1600, 3200 etc. with sneaky half or third steps in there depending on how your camera is set.
Shutter speed is how you capture motion so you need to know how fast your subject is moving. The faster the shutter speed, the more your subject is frozen in time. But if the shutter is not open for very long, hardly any light gets in. A photo of a posing person could be taken at 1/30, a candid kid shot at 1/125, a horse might need 1/250 (a guess). If you have shots where the horse's legs are blurry but the rest of the shot is not so blurry, that's a shutter speed that's too low. You can try to use a lower shutter speed by following a moving subject, called panning. The lens focal length matters because higher focal lengths magnify camera shake, and how fast the subject is crossing the frame.
Quote: My major problem is when I try to play with settings, sometimes it will refuse to take the picture and I don't know which setting is the culprit. I remember using a 35mm out of highschool, and taking pics is so much more cost effective these days, as a hobbist you don't pay with anything but your time for mistakes, but if I don't know what the problem is I cannot correct it.For safeties sake, I'd like to stay away as far as possible. There can be a half dozen horses working in the large arena at a time. But, I realize that doesn't work well with a zoom for the reason you stated - loss of light. My focus is my girl, but I do take pictures of everyone when it's my turn/week.
That is probably the camera telling you that it doesn't think your focus is right.
Quote: The Gemini I mistyped, it actually is 135mm. It's an odd lens and as a (not true) macro it's cool, but as a long range prime it's not helpful at all.
I was going to suggest a 135mm f2.8 because they are cheap. It often isn't really long enough, but it does open to f2.8. If you get a decent shot, you can crop it to make the subject larger. I would try using it again and figuring out the problems. It's manual focus which is not easy, but it is free.
