Originally posted by Sagitta How low is low for the budget? You can pick up the Samyang 1.4's for a few hundred bucks, less if you catch them on sale.
I have the 85mm f/1.4 and the 35mm f/1.4 and I think they cost me under $600 for the pair a few years back.
EDIT: You can probably use the K50 at ISO 1600-3200 without too much trouble if you pop for a good denoising software of some sort.
$600 is way out of my ball park, UNFORTUNATELY, we are in the $100 arena. Wasn't sure if it could be done, but it never hurts to ask - and I know what to look for when I am on eBay, craigslist and letgo scouting for deals. I do have Adobe Photoshop 13, which does a fairly good job of fixing afterwards whatever happens between my eye sees and the camera captures. Not sure if there is anything better that's not in the 100's of dollars range, which is not doable. I
---------- Post added 10-06-16 at 05:51 AM ----------
Originally posted by bigdavephoto For a lens that would be good, if you don't need a zoom lens, try the DA50 1.8. New I think it runs around $120. Used can be as low as $70-$80.
I would also suggest getting out of auto. For shots in fading light, you really need some control over the camera. If you don't want to use Aperture priority or Shutter priority, put your camera on the P mark so you can have some control. With your camera in P mode, the camera will work in auto unless you move the front or rear dials. I believe the front one is for shutter control, the rear one is for aperture.
Another thing about using P mode is that if you want to, you can also control what ISO you are using. For photos in twilight, I would move the ISO up to 1000 or even as high as 6400 or higher if need be. I don't have a K50 so I am not familiar with it but if I remember right, (going off of my K7 and K5II-s) you will need to go into the menu and allow for expanded ISO.
I am sure some of the other members that are not lazy as I am when it comes to photography will pop in and give you some better advise then what I have. What I said is a start.
Thank you. Now I know where to start and what to look for. I am not being lazy, it's just that there is SO much that knowing where to begin sometimes feels impossible. You have to know what setting you need to change before you can look it up in manuals or books, and googling it leads down countless rabbit holes. I tend to get overwhelmed, and if I know where to focus FIRST then I can add things as I go on. A zoom lens would be great, but I notice the issues really ramp up as the zoom depletes the light around the darker subject, so cropping isn't a big issue. Thank you for pointing me in the direction I need to be looking!
