Originally posted by koekie Have my eyes set on buying a recent Pentax DSLR, but I need some advice on lens choices to really convince me to go the Pentax way (as opposed to going MFT).
Welcome! We can be a bit of a rowdy bunch, but I think I can find you something that will make you happy.
Originally posted by koekie Basically I have 3 or 4 types of photography I will do mostly:
- Daytime landscape
- Evening/nighttime city shooting
- Astrophotography (basic, not planning to go for tracking mounts and such)
- Some occasional bird/animal shooting (at telephoto distance)
Keep in mind that 35mm and 50mm lenses you found are the 'bargain barrel', so to speak. They produce fine results from what I've seen, but you're making some serious compromises. You've found some lenses to work between for genre 1, so let's consider the others.
2) Try the 20-40mm Limited. The DC motor is amazingly quiet; excellent construction (makes me want one, I just don't have a use for it); decent aperture range while light-weight, and can be had cheaply enough if you shop around [there are a couple used on B&H for $500]. The focal length range is perfect for street shooting, even if I prefer the 40 or 43 limiteds for that work.
3) I really recommend you check out the Vixen Polarie tracker. Don't bother with the accessories, just the tracker, a tripod and a second ballhead will do wonders for your astrophotography. There are plenty of lenses in this range... perhaps the Samyang 14mm [$329]? Manual focusing is the rule for astrophotography anyway.
4) I actually like the 50-135mm or the 100mm Macro for this purpose, but most birders prefer a longer zoom. How about the 55-300 PLM [$400]?
