02-14-2007, 04:11 PM   #1
50mm/1.4 vs 55mm/1.8
I have an old 55/1.8 that came with my KX years ago.
I'm comfortable with manually focussing it and setting exposue manually.
I've read very positive things about the 1.4 and seen great shots from it.
Apart from the 1.4 vs. 1.8 aperture would I see a lot of difference in image quality betweem these two lenses?
If yes in what respect?
02-14-2007, 04:23 PM   #2
Yes.
Most notably the bokeh is different, with the 1.4s generally regarded as being more pleasant.
While I am happy with the sharpness of all my 50s, I know the 55/1.8s are generally well-regarded here. Some are critical of the 50/1.4s although the DOF is so thin that often times focus errors account for the softness.
You'll also notice a brightness difference between the two in the viewfinder.
I have an old Auto-Takumar 55/1.8 that performs well, and this without the SMC coatings!
02-14-2007, 04:30 PM   #3
baw
Thanks for the fast reply!
You mean due to 1.4 / 1.8 difference, or due different glass/coatings etc.?
02-14-2007, 04:36 PM   #4
Both, depending on which 50/1.4 you're comparing to. Pentax has updated even its SMC coatings over time, so there is a difference between the Super-Multi-Coated Takumar 50/1.4 that I have and the smc Pentax-FA 50/1.4 that I also have.
...and they are both different from the SMC Takumar 50/1.4 and both of my Super-Takumar 50/1.4s.
02-14-2007, 04:56 PM   #5
QuoteOriginally posted by baw Quote
Yes you would. I have an old 55/1.8 and I have had several different A and FA 50/1.4 lenses. In my experience the 55/1.8 is a bit soft (both contrast and resolution) up to around f/5.6. Maybe not by much but there is a difference that sometimes will make you wish the 55/1.8 really was an FA50/1.4.
02-14-2007, 05:04 PM   #6
fwcetus's Avatar
IMHO, the 50/1.4 (K, M, A, F, or FA) will, despite being the faster lens, be sharper at apertures wider than about f/8. The K 55/1.8 is a bit soft below f/8, but is quite good from f/8 and narrower.
02-14-2007, 05:09 PM   #7
Soft, huh?
Now I know. Is this the general consensus on the K55/1.8?
02-14-2007, 05:22 PM   #8
fwcetus's Avatar
QuoteOriginally posted by carpents Quote
Soft, huh?
Well, only at wider apertures. At mid-apertures and smaller, it's really quite sharp.
02-14-2007, 05:34 PM   #9
55mm f 1.8
Soft, huh?
Don't know about the K55/1.8 but - I have both the 50 f1.4 SMC m42 (later version) and the 55 f1.8 SMC m42. The bokeh on the 1.4 is definitely better, the difference being noticeable in the rendering of out of focus points of light. (the 1.8 sometimes has clashy disks or rings of light, the 1.4 less so). The 1.8 is not at all soft, even wide open (don't know about corners full-frame, since I use a DS) and may be a bit sharper at 1.8 that the the 1.4 is at f1.8. Also, I think that at infinity the f1.8 might generally be sharper than the 1.4, at least at the wider apertures (based on test photos I did of distant brick walls). They are both great lenses with the 1.8 having less "personality".
02-14-2007, 05:38 PM   #10
QuoteOriginally posted by fwcetus Quote
LOL, I consider f/8 to be the smallest aperture in existence.
02-14-2007, 06:07 PM   #11
Alvin's Avatar
I have used a SMC-K 55/2 and I now own a SMC-M 50/1.7. I find the 55 is a little softer wide open and at 2.8 as well. The 50 is sharper by a touch, but that could be me still getting used to trying MF.
12-17-2019, 10:35 AM   #12
Strange - in the PentaxForum Reviews the 55mm f1.8 has a better rating for SHARPNESS than the 50mm f1.4
Yet the comments here seem to say other wise. However there are over 180 reviewers who give the 55mm a 9.4 average for sharpness, whilst the 50mm only gets 9.2 (although 9,2 is pretty amazing too!)
lol
k-mount, pentax lens, slr lens, vs
For Sale - Sold: Pentax M 28mm 3.5, Sears 55mm 1.4, Ricoh P 50mm 1.7, Chinon 50mm 1.9 (Worldwid causey Sold Items 17 01-08-2011 11:14 AM
For Sale - Sold: K10D + grip + 18-55mm, DA 12-24mm, FA 50mm/1.7, D FA 50mm/2.8 macro (Worldwide dgaies Sold Items 6 07-17-2010 03:46 PM
For Sale - Sold: Pentax *ist DL, FA 50mm f/1.4, DFA 100mm f/2.8 macro, DA 18-55mm, A 50mm f/2.0 chemxaj Sold Items 14 05-31-2010 09:34 AM
50mm/1.2 or 55mm/1.4? axl Pentax SLR Lens Discussion 26 05-28-2010 12:18 PM
For Sale - Sold: A 50mm 1.7; M 28mm 2.8; M 50mm 1.4; 18-55mm II; Sigma AF 24mm 2.8 II. thomasxie Sold Items 4 03-05-2010 06:33 AM
All times are GMT -7. The time now is 07:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
