07-28-2008, 10:23 AM   #1
K-Mount Trick! (& Question)
I am waiting for a k-mount 135mm f2.8 lens from eeebay (with the best name EVER! the Magnum!!!), but have been playing around with my new-to-me k-mount 28mm f2.8. I have tried to use stop down metering with no luck.
What I found works is that instead of locking in the lens, you set the lens to f22 (or smallest aperture), start to put the lens on, and stop turning when the aperture blades start to move just a little bit. Then you can use the TTL metering while turning the aperture wheel. It works like a charm!
Now my question to you is how do you stop down meter? I've heard to use the optical preview, press the AE-L button, the take the picture. Bt my pics come out way over/under exposed.
Another question, when I try to use the built-in flash it is completely over-exposed (even with the flash exposure compensation to -2) Thanks in advance!
07-28-2008, 10:34 AM   #2
K100D (Super) Pictorial guide to using manual lenses [imgs] [Page 1]: Pentax SLR Talk Forum: Digital Photography Review
second post down titled "shooting" explains step by step how to stop down a manual lens on a K100D. Hope that helps.
07-28-2008, 10:42 AM   #3
QuoteOriginally posted by MrApollinax Quote
Thanks! My problem was that it wasn't put in M "Mode". Thanks for the link!
07-28-2008, 11:07 AM   #4
Jodokast96's Avatar
As to using flash, and this is for any flash with any lens, proper exposure relies more on the aperture than shutter speed. In this specific case, the flash will fire at full power, so you will need to stop down the aperture to one that will give you the exposure you need.
aperture, f2.8, flash, k-mount, lens, pentax lens, question, slr lens
Hey new here, quick question, is this K mount or M42 Screw Mount? Lulerfly Pentax SLR Lens Discussion 8 11-02-2010 11:58 PM
For Sale - Sold: Kaleinar 3B 150mm f2.8 Pentacon 6 mount & Sigma 28-70 EX DG cas Sold Items 8 10-28-2009 10:51 PM
For Sale - Sold: Pentax SP500 Screw Mount Camera & Lens KmountShooter Sold Items 1 07-18-2009 12:02 PM
M42 lens adapter question & KA mount greenboy Pentax SLR Lens Discussion 15 01-25-2009 09:43 PM
All times are GMT -7. The time now is 02:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
