Originally posted by Adam For 645 lenses, A, FA, and D FA lenses cover the film 645 format, whereas DA lenses are designed to only cover the reduced 44x33mm format.
And the 645
film format is not actually 60mm x 45mm but
56mm x 41.5mm. The DA or
digital medium format uses the 44x33mm that Adam is referring to.
So according to basic geometry, the diagonal of the 645 image is 81.12mm, so that would be the minimum diameter of the image circle for a wide angle lens like a 35mm. Keep in mind the image circle increases with the focal length, but due to the focal plane gate, itʻs always cropped unless you have a non-rectilinear fisheye.
Would be curious to see the actual data base for the image circles.
