Originally posted by tommygunn84 Would the pentax 50mm F1.8 SMC DA be better than the HD 100mm macro pentax lens because i'm about to make a purchase and the 50mm f1.8 smc da is an added deal option but do i really need it with the 100mm macro for face portraits?
As I said earlier (and others have said too), I don't think the 100mm macro is great for (human) portraits. The focal length is a bit long to be convenient for portraits on APS-C in many situations, but the main issue is that images are not flattering (too sharp and flat). OK, maybe B&W wrinkly old folks if they don't mind, but for other portraits use the 16-85. (As Uncle Vanya points out, the slower aperture is a limitation, but people use these kinds of zooms every day for portraits and get good results.) The DA 50 f1.8 is very good for portraits (think of it as a poor person's DA Limited), and it's a handy low-light lens generally (the wider aperture complements the slower apertures of the 16-85 zoom). It's not WR, but it's very light and great for the money. I'd get it in the package if the price is good. You could easily sell it later if you get a more expensive lens to take its place.
Portrait lenses are another whole topic. People will probably tell you that the gold standard for portrait lenses for APS-C in Pentaxland amongst current lenses is either the DA*55 or the FA 77 Ltd, or the DA*50-135. Plenty of threads about this. The DA* models are WR, the 77 isn't - but WR isn't really essential for most people in a portrait lens (unless you specialise in portraits in the rain or under waterfalls ;-)). If you don't know, just wait. Try the 16-85 zoom for a while (good choice IMO) and see which focal lengths you prefer for particular types of images. Then you will have a better idea about what specialty lenses to get.
Originally posted by narual Or you could just follow the advice you've gotten over and over again from most of the people in this thread... get a couple of lenses and buy more if you feel that your current options are lacking once you've actually started using them.
Absolutely agree.
---------- Post added 11-02-16 at 09:43 AM ----------
Originally posted by tommygunn84 .. and do I really need a flash if so which one? will I need a ring flash for macro and can they be used for other general work as well?
also what is a good light and cheap tripod and what accessories shall I get such as filters, memory cards, spear batteries, filters ect....
Norm has answered most of these questions. My quick comments:
- ring flash? Wait and see. Get a general flash first. I'm guessing that you are not looking at multi-flash/wireless options, and you want something lightweight and unobtrusive for fill, street shots etc - just get a small cheap simple P-TTL flash to start with, like the Metz 24:
https://www.pentaxforums.com/accessoryreviews/metz-mecablitz-24.html. You can use it off-camera with a generic P-TTL cord if need be. You don't necessarily need a very powerful flash for most macro (unless you are out in the field with large softboxes shooting fungi, like @BrianR :
https://www.pentaxforums.com/forums/125-flashes-lighting-studio/311090-lighti...close-ups.html ). Some kind of portable diffuser/bounce card is useful too.
- Tripod. Don't go too cheap here. Buy quality, buy once. Carbon fibre - Sirui, Induro, something like that. Get a decent head too. Search the many threads on this. A Gorillapod can be handy for travel/street too. Get a single type of attachment system (Arca Swiss or Manfrotto seem to be the default standards) and use the same sort of plate on everything.
- Spare batteries. Yes, get two. Third party are OK. Maybe get a third party USB charger too.
- CPL Filters. I agree with Norm that a good CPL is worthwhile. They are not cheap. Kenko Zeta are good value. You'll need a 49mm for the DFA 100, a 52mm for the DA 50, and a 72mm for the DA16-85, If that's too much, at least get one for the zoom. If you get a 52mm filter for the 50mm lens, you could also get a 49-52mm step-up ring (that is a cheap adapter) to let you use the same filter on the DFA 100. If you do that, you won't be able to fit the lens hood on the DFA; but a cheap solution would be to get a 52mm three-position rubber hood to screw into the filter thread. That's a useful thing to get anyway if you get the DA 50, because it doesn't come with a hood. Otherwise, get a 49mm filter for the DFA 100 (which will fit a range of other Pentax lenses) and use a step-down ring to let you use it on the DA 50. That way you can use the DFA 100 with the filter and its (deep) original hood.
- Protective filters are a matter of debate. When in doubt, go with what Norm says.
- Memory cards. What Norm said. Shop around and you can get good deals on quality cards like the 64Gb SanDisk Extreme Pro.
You will need a suitable bag too. The best idea is to take your gear into a good camera shop and try out various ones.
And also a sensor-cleaning kit, if you don't already have one. At least a blower like the Giotto's Rocket, and preferably a silicon or sticky pad lollipop and/or some wet cleaner and swabs. Dust-Aid makes a good starter kit.
