Originally posted by clackers Legacy zooms and wide angle primes are weak compared to today's products, Peter. I mean, that's across the industry, not a particular brand.
But if you must, you could try something like the F 70-210 f4-5.6. Has just a 49mm filter size. The Sigma 70-300 DG f4-5.6 is newer.
I don't fully concur with your statement.
I would reword it as:
"the best, very expensive zooms of today (fast, same max aperture across focal range) are sharper and give more contrast than film-era zooms. Especially wide open"
Though the best vintage zooms, if used at their sweet spot and with some post-processing, can still offer an incredible price/value ratio and take very sharp pictures.
I agree with your choice of the Pentax-F 70210mm. Pretty good.
For a wider focal range i'd go for the Sigma Apo Macro 70-300mm last version. Pretty decent, AFAIK. I have the older version, which seems a little worse.
For shorter focals, i'd go for the Pentax-F 35-70mm, the Pentax-FA 28-70mm f4 AL, and the Pentax-FA 24-90mm.
From very cheap to not expensive.
If manual focusing is not a problem, the two Pentax-A 35-105mm f3,5 and 70-210mm f4 can still be found for almost nothing, and should perform well on the K-1 (if stopped down a little).
Pentax film-era AF zooms look plasticky and a bit wobbly, but they are very well made. More the series F than the FA, i'd say.
Very likely "screwdriver" in-camera AF motors of the time didn't have enough torque, so the lenses had to be made that way.
I can't say that i'm impressed by the build quality of recent high cost Sigma zooms.
The old EX DF version of the 28-70mm f2,8 sometimes gets stuck at minimum focusing distance, and i have to free it manually.
The 24-70 EX DG f2,8 has been a nightmare. May bad, probably. I purchased it on Ebay, like new, no bumps no signs of use. Tried it quickly at home with the K-5 II: everything seemed ok and i released positive feedback. Since then has been kept dormant, waiting for the K-1 (i had better options for APS-C sensors). By mistake i sent it to the official repair service of Sigma Italy, together with a 120-400 that has to be upgraded for free for the new K-1, and a 30mm DC with damaged front glass. Yesterday i've been contacted by email: the focusing helicoid has a problem close to infinity and the zoom guide is bent. 200 euros for parts/assembly/checking/fine tuning. The lens showed no damage whatsoever. Like new! Probably it just took a bump on the front, on a kind of surface that left no traces.
Some of my Pentax zooms took a few hard knocks, but all of them still work as new.
Even the Sigma zooms that give no problems, like the 10-20mm DC or the 120-400, give me a distinct feeling of quite feeble innards.
A little better feeling with my primes, like the three macros... which are VERY good optically.
cheers
Paolo
