Originally posted by Kunzite Undoubtedly? Do you have any proof for this, then?
For the love of god, It's a matter of public record: Look it up, i'm not going to help you if you can't help yourself.
Originally posted by clackers In fact, let's look inside Namioka.
good find, and some interesting information there.
Originally posted by yurko_yr Tamron has at least two factories where they grind lenses: Hirosaki factory and Namioka Factory in Niigata prefecturs. The later one is producing asferical and ultra small diameter lenses. Also the other plant is located in China - Foshan Factory.
I wasn't aware of the namioka factory...but then again I don't pay as much attention to third party lensmakers as I probably should....they are a fickle crowd.
The real question is: who is doing the coatings? You cannot rely on the appearance of the coatings on the lenses themselves, to be accurate at all you would have to disassemble the lens completely and examine the coatings on both sides of the elements under controlled conditions with a spectrometer to measure and compare the bandwidth of transmission/reflection of each element.
Tedious work.
....or you could just ask Tamron.
