Originally posted by Obin Robinson Stunning images, that's for sure! Interesting suggestion too, but I guess it's coming at least one year too early
Basically I am still a beginner at serious photography, and especially in stuff like astrophotography. So I guess it makes more sense to try and get the best results with the more common and regular APS-C lenses which are easier to use. Using medium format lenses sounds interesting, but I guess I'd better take the time to try and learn the craft before looking into anything like 67 lenses + adapter.
Originally posted by Adam I've never been a fan of zooms for astrophotography. Many things make getting clear star photos difficult, and I think that having a lens that isn't as bright or sharp as it could be can make a successful shoot even harder. You need the lens to perform really well wide-open, so that should be your top criteria if you decide to go for a zoom. Going by that, the DA 16-85mm may indeed be more viable than one of the F2.8 zooms if you plan to shoot mainly at the wide end.
I'd personally recommend the Samyang 16mm F2 for your wide-angle shots, and any fast wide or normal prime for your deep space shots. The Samyang 24mm, 35mm, and 50mm F1.4 would all be viable candidates. And since AF doesn't matter for astrophotography (you could even argue that manual focus lenses are better since they allow for more precise adjustments), there's no harm in going for these lenses and saving some money.
Ye I also considered the 16-85mm, as I have been reading about its sharpness and excellent performance all across the board. However, I kind of figured that the 2/3 stops of less light coming in (f/2.8 vs f/3.5) would automatically make it less ideal than the Sigma/Tamron 17-50 2.8 for wide angle astrophotography.
So basically you are saying that the better performance/sharpness of the he DA 16-85 at the fl of 16mm is preferrable over 17mm at the Sigma/Tamron, even though these two lenses have a slightly larger aperture and thus will let a bit more light in? Interesting point for sure! And perhaps the good ISO performance of the K-70 helps a bit here too, compensating for the f/3.5 aperture at 16mm?
Perhaps I should consider the Sigma 17-70 as well. According to the reviews here, its just as sharp at 17mm, while being a bit faster and atm roughly 150 euros cheaper than the 16-85. Although it seems kind of hard to imagine that that Sigma 17-70 would be better at the wide angle than the Tamron/Sigma 17-50 right?
Well I already have the two Pentax plastic fantastic lenses. The Samyang equivalents are probably better, but pricewise you can't beat these two small Pentax lenses. And a
review on lenstip showed that the 35mm 2.4 is excellent when it comes down to coma in the corners. They are both quite fast too.
Originally posted by Obin Robinson Ye I already read about the sharpstar on Lonely Speck. Certainly seems like an interesting tool. But isn't the use of the 10x 'ok-button' live view zoom method on a bright star (+ meticulously adjusting focus manually until you have the star as small and sharp as possible) ok too? Probably this is not always the most precise method, but it also seems a bit more fun just using the camera + lens to get the best focus possible.
