Originally posted by robthebloke 1. If you're on tripod, turn off shake reduction.
2. If you're hand holding, turn on shake reduction!
3. The DA* 300 is a lens that demands TAV mode. Set the shutter to be say 1/500 (less if you're brave!), and knock the exposure compensation down a bit (I usually use between -0.7ev, and -2.0ev in extreme cases). The biggest problem is maintaining a high enough shutter speed to get the shot. If it's underexposed (which is very common in the evenings and mornings), then you can usually pull a good looking image out of the shadows in Lightroom.
4. In some cases, spot based AF helps (e.g. Bird in a tree). In others cases you'd be better off using all focus points (e.g. Bird in flight). Set up a couple of user modes on the k-3 so you can quickly toggle between them.
5. Practice with the lens a *lot*. It's not the easiest lens to use on the k-3 (it's actually a lot easier to use on the k-1!). At first your hit rate will be bad (especially on overcast winter days). But it does get much easier on a bright sunny day! (I got mine in the Black Friday sales last year, in November, when it was bloody dark! The results weren't great. it was obviously good wide open, but it takes practice to get good results when stopped down - or bright sunshine!)
Great lens though! I just picked up the 200 to go with it (faster aperture, easier to use, but doesn't quite attain the level of the 300 imho!)
Just to add to this:
I think @robthebloke nailed it...
Turn OFF shake reduction in general > even hand held I've noticed it will introduce motion blur when I use it on my K-3ii. Perhaps I have a very steady hand? idk, but that's just my experience with SR and the DA*300 on a K-3ii
Also I shoot in manual mode, so can't attest to the TAV mode - But I will say any shot under 1/450 is usually a throw away...
I usually say the shutter has to match the 35mm equivalent FL. So 1.5x 300 = 450. That's my starting point.
I also notice my K-3ii tends to overexpose images, so if the image looks dark on the post-shot preview, don't worry too much. I have noticed that most shots that are underexposed I can save in lightroom. Any overexposed shot is generally harder to fix - Again this is just my experience.
Focus and Metering I use single point spot.
Also use rear AF button and turn off half-press shutter focusing... This has helped IMMENSELY when it comes to nailing the focus on small objects in trees and even birds in flight! - Just keep your arms steady and pivot at the hips when tracking a bird in flight. Look at @Heie 's article (
Making the Most of Long Exposure Handhelds - Introduction - In-Depth Articles) about keeping steady at low shutter speeds in the field without a tripod/monopod. That's a great article for learning new techniques. I tend to use the "elbows in, almost touching" approach when in low light and need to drop shutter speeds.
The best way to improve a skill is by failing.
Learn from your mistakes and adjust, modify, research.
I would wait for a sunny day and take some shots at ISO100, 1/1600 and F4; F5.6; F8; F11. Shoot from a tripod if you can, or try the elbow lock method in the article I reference above.
Check sharpness - and post photos here!
Cheers!
Logan
