Originally posted by zizo
Well thanks for the help Ole, but i've been told that i need a lens with an aperture of at least 2 with 1.4 even better for low light. what do you think? as for 24mm zoom with ISO 1600, you get lots of noise don't you? Thanks for your help, i really value it.
Ideally yes, you go with a fast lens. But the good thing about the DSLR is that you can bump up the ISO to 1600, even 3200 in lieu of using a faster lens. You can remove the noise in the photoediting software. Of course, you don't get quite the same quality as at ISO 200. On the other hand, with the fast lens you won't get any depth of field at f/1.4 and you will also lose some resolution.
I do have the 50 f/1.4; most often I use the 24-90 zoom at 24mm where it is a f/3.5 lens and bump the ISO.
It's really up to you. But saying that you "need" a fast lens is not quite right, you can make do with what you have, and then, perhaps when you from using the zoom get some experience in what focal length is your favorite, buy the right prime for you.
