The DA* Prime lenses perform very well and sometimes shine at their lowest aperture. The only exception to this is the 50-135 and 16-50, where they need to be stopped down a bit to really see the sharpness.
Someone mentioned in this thread, the DA* SDM line from this generation is known for SDM failure. If you haven't had failure, you are in line for it. Good news is that it can easily be overcome with fairly simple "hack".
Here is a link to video I created for this procedure. The 60-250 and 55 SDM can't be hacked unfortunately. The 60-250 because we don't have the correct config adjustments, and the 55mm because the lens doesn't have a screwdrive.
I wouldn't let this keep me from buying a DA* lens, as long as it could be converted to Screwdrive should the SDM die.
