Originally posted by Bui The only thing I did differently was to set the AF/MF camera switch to AF. I always thought it should be "MF", is is normal or my KX has some problems?
Again, this is as things work. You are too paranoid
Read the manual. Lens has to be MF mode (which all manual focus lenses are) and camera has to be set to AF. And the lens mount has to be metal, not coated with non-conducive layers.
This is why you cannot use CiF with modern DA lenses. They have no AF/MF switch on the lens.
Originally posted by Bui And with CiF like this, I can't use the green button, so with K and M lens my camera will always shoot wide open, right?
Why not? CiF has no effect on green button metering. You get as close to the right focus as possible, then you press green button, and them you press shutter button.
And
no, camera will not shoot "wide open" just because you do not press green button. Green button is only for metering, it stops down the lens and takes the metering and sets the shutter speed. You can take photos in M mode, with whichever aperture you chose on the lens. M mode stops down. Av mode does not. Green button and Catch in Focus have no effect on this. Check the LCD screen on your camera, it says M or Av to notify you which mode it is in so you know what it will do.
