07-30-2008, 05:44 AM   #1
dslr focal length multiplier and lens hoods
Does the angle of view change on a lens due the focal length multiplier (1.6x)?
If I put my 50mm on an slr, is it the same angle of view on my k200d?
The reason I ask is that I'm looking for a lens hood for my 50mm. Should I be looking for a hood that will accommodate a 50mm or an 80mm?
Does size even matter? Would the slightly longer lens hood even make a difference?
This is assuming that the larger resulting focal length will give a narrower angle of view.
Thanks -Dave-
07-30-2008, 06:04 AM   #2
pschlute's Avatar
The 50mm lens on a crop sensor DSLR will have the same angle of view as a 80mm lens on a 35mm film slr yes.
This should mean that you can use a narrower hood on the 50mm, but in practice i dont think it will make a lot of difference. Just get a "normal" hood or the one designed for the 50mm lens.
07-30-2008, 06:18 AM   #3
Wheatfield's Avatar
QuoteOriginally posted by dmoon911 Quote
Thanks -Dave-
Technically, you will want a lens hood designed for a longer lens if the hoods are designed for film use. You will find that most of the time it won't make a heck of a lot of difference, and that some of the time it will make all the difference in the world if you use a shorter than optimal hood.
This is the one and only time when I see a reason for the silly focal length multiplier that people insist on using.
Your 50mm lens does not magically turn into a 75mm lens when you mount it to a DSLR, but the hood that goes onto the lens should be designed for a 75mm lens (presuming the hood is designated for film use).
07-30-2008, 06:34 AM   #4
Lowell Goudge's Avatar
you might wish to try this link
Custom lens hoods
What you need to remember is that the lens diameter IS NOT the filter diameter, but the actual lens diameter of the front objective.
You have to pay to get teh PDF Output, but the Idea is to make your own out of relatively stiff material, and wrap in around a filter ring.
50mm, angle, hood, k-mount, length, lens, multiplier, pentax lens, slr lens, view
What does the DSLR do with the focal length info when using MF lenses? Ari Freund Pentax DSLR Discussion 15 02-25-2010 07:38 AM
Focal length on M-series lens jackbullet Troubleshooting and Beginner Help 16 07-31-2009 09:01 AM
SLR > DSLR focal length conversion? wedge Pentax SLR Lens Discussion 20 07-28-2009 05:05 AM
What is your most used Lens/focal length Fl_Gulfer Pentax SLR Lens Discussion 43 02-21-2009 12:36 PM
One lens, one focal length. Forever. pingflood Pentax SLR Lens Discussion 54 12-05-2008 06:01 PM
All times are GMT -7. The time now is 03:03 PM. | See also: NikonForums.com, part of our network of photo forums!
