Originally posted by danlam Let says I put the focus on infinity and take two pictures, one at a low aperture and one at a higher aperture - both will have different sharpness/ focus? Regardless of shutter speeds?
If you focus on infinity and take one shot stopped down to say f/11 and another one wide open at f/2.8, the main difference you see will be in the corners of the frame. At f/2.8 the centre might appear sharp, but the corners will be more or less blurry depending on the quality of your lens. At f/11 you should get good sharpness right across the frame, unless your lens is really hopelessly awful. You'll also get more depth of field at f/11: more things from the front to the back of the scene will appear to be in focus.
As for exposure, you need to learn the principle of reciprocity, which governs the relationship between aperture and shutter speed. Let's say you're using f/11 and your camera's meter indicates a shutter speed of 1/60.
f/11 = 1/60
f/8 = 1/125
f/5.6 = 1/250
f/4 = 1/500
f/2.8 = 1/1000
Those are all exactly the same amount of exposure -- they each let the same amount of light hit the film. For a landscape you'd want to use f/11 and 1/60 and maybe a tripod to get the best sharpness and depth of field. For an action shoot you'd need at least f/4 at 1/500 to freeze motion, and you'd have to accept a loss of some corner sharpness.
