Originally posted by dtra This is the first stage of the problem I had. If the screws are loose, the focus can become off. If they loosen up all the way, the lens separates. Those 3 screws connect the front element to the focusing mechanism and set infinity focus. When they get out of alignment, the focusing will stop before the lens reaches infinity (or can go the other way).
You need to remove the front covers (the first two are held by sticky tape, then the third cover has 3 tiny screws). Don't remove anything on the mount side. If any of the screws is completely out, put it in right away, but not too tight. You may also need to loosen the screws up a little more, but in any case get all three in and a little loose, and then rotate the front element relative to the focus mechanism (I did it by pushing on the screws in the direction of rotation). You should see marks where the screws belong. Once it's back in the right place, tighten up the screws, check for infinity focus. You may need to adjust a little bit one way or the other to get it in the right place.
Once you get infinity back on the mark, remove the screws one at a time and put a drop of thread locker on them, then tighten. It sounds scary, but it's really a very easy repair.
