Show Printable Version 9 Likes Search this Thread
11-24-2016, 01:41 AM   #1
Pentax 77mm repair. DIY attempt?
Hi
I have a 77mm lth where the rear elements have come loose. It is second time this lens falls apart. First time I had in professionally fixed by some super friendly Sikhs, but to be honest they didn't do a good job (always had issues around infinity) and I suspect it fell apart again because they didn't do a good job. That, however, was a repair center in India as I was traveling when it happened.
So now I am considering if I send it off to repair again or attempt to do it myself. The lens is way out of warranty.
I have the tools and motor skills to deal with tiny screws and such, so I think I'll be able to take it apart and but it together again. However, will it perform 100% as supposed ...?! There are some guides on other lenses, but does any of you guys have experience with the 77 you can share?
Or, other option is to send it off. I have bad experience with Pentax service in Denmark, where I live, as well (they charged me more for repair than the lens, a 12-24mm, cost as new. But at least it is working now). Service is now done by a different company, which is located in some small Swedish town. Any experience with these guys? Or some alternatives - there used to be a company in Germany?
Sorry for long post!
11-24-2016, 02:50 AM   #2
QuoteOriginally posted by H. Sapiens Quote
Hi
I'm not an expert, but a couple of thoughts:
  • I believe there's an 'exploded' diagram for this lens. That sounds helpful.
  • Wall off your deskspace! I've tried opening a lens before, and my kit 18-55 was never the same.
  • Expect flying springs!
11-24-2016, 03:16 AM   #3
QuoteOriginally posted by lithedreamer Quote
That was what happened to my FA20.
Pentax square in Shinjuku told me it is an old design lens. They cannot open the lens up there for it is no hope to fix my FA20.
so I back home and try it myself ( I open up and fix my DA15 before. ) I try open it from the rear part first. (b/c It seems impossible to open it from the front part.) And as soon as I remove the last screw, those cute tinny springs fly out in all direction! That's when I understand why professional at Pentax square said they cannot open it up. LOL
What I found inside the FA20 is, they have a lot of small gears running along inner lens barrel. Which even If I manage to find all loosen springs + manage to put all of them back, I have no idea what need to be fixed. It looks very complicate in there which is so difference than a newer design lens such as DA15. I guess the same era FA lenses might use a similar design approach? I am not sure about FA limited lenses.
if you really like the lens, let professional check it first, trust me!
Good luck.
11-24-2016, 03:40 AM - 1 Like   #4
Yes, you are right - I downloaded the diagram dreamer.
I have some experience with manual watches and got a loupe, tiny screwdrivers and such - that's why I'm kinda hopefull :-)
I would still like to hear first hands reports with that lens! Needless to say, it is not a cheap oldie you put on the shelf for display, when you can't get the thing to focus on anything again.
11-24-2016, 03:58 AM - 1 Like   #5
I'm glad to hear my advice was of some use. The shipping might make this option prohibitive, but I thought I'd throw out the option of sending it to Eric, the independent Pentax expert. This thread is kind of relevant. I searched around the forums and wasn't able to find more helpful threads, sorry!
11-24-2016, 05:13 AM   #6
That was useful. I realize that I have treated JIS and philips as the same screw. I must look closer what I have among my watch tools, but of course most of the screwdrivers are flat head, which is what is used for watches. I think I have to realize it must be shipped up to those folks in the Swedish forest. It is going to cost a bloody fortune...
My lens looked like Mike's when I first took it to repair in India.
11-24-2016, 08:12 AM   #7
Ontarian50's Avatar
Even if you have the motor skills and mechanical aptitude to deal with the disassembly and re-assembly of a precision item like your 77mm - a big obstacle to DIY camera/lens repair is having the right tools.
High quality screwdrivers are hard to come by (I have to order mine from California). And the various pin spanners, etc. that are essential for some lens designs aren't something ever seen at the local hardware store.
So, to do it right, and not damage anything because of inadequate tools, you have to make an investment in the right stuff. Don't get me wrong, some people really love having a kit of precision tools of their own. But if you don't plan on working on lenses in the long term, get a pro to do it right for you.
11-24-2016, 11:45 AM - 1 Like   #8
Dude! That's amazing. I only had a glance now, but I don't think it looks too intimidating. I'll buy some Threadlock and give it a go.
Enjoy thanksgiving! We have adopted Halloween and Black Friday and a few other holidays from over there, but don't see the point in giving thanks.
But what the heck ... Thank you!
11-24-2016, 06:50 PM   #9
WPRESTO's Avatar
A problem I foresee is precision alignment (collimation - decentering) of any lens elements that be be loosened. Not something that can be corrected at home by eye.
11-25-2016, 05:38 AM   #10
WPRESTO's Avatar
QuoteOriginally posted by dcshooter Quote
Decentering in a prime is only caused by either an original manufacturing defect (e.g. a mis-cemented doublet) or by physical deformation of a barrel caused by a blow to the lens. As far as "collimation" goes, 99+% of slr lenses can't be collimated, since they are composed of elements held in by fixed retaining rings that can't be adjusted axially. If you've had a tech claim that he collimated a lens for you, you've likely been a victim of fraud.
Screwing and unscrewing enyire lens cells will have absolutely no effect on the centering of a lens, and single elements will only be a problem if you remove them and don't put them in flat. As soon as the surfaces are flat, the mechanical and optical centers of a modern lens are so well aligned that their rotation (the only adjustable parameter) is irrelevant to performance.
OK. I learn something new each day. Way back when I dismantled some ancient lenses (pre WWII), it was necessary to use a spanning wrench to loosen a locking ring to remove at least some lenses from the barrel, and several lenses had "play" when replaced.
11-25-2016, 05:56 AM   #11
Try and practice on some old Takumar lenses for a bit of experience.
11-25-2016, 05:58 AM   #12
QuoteOriginally posted by WPRESTO Quote
I have also only taken one lense apart and put it together (an a-series) and it occured to me that the only thing keeping the elements positioned is production telerances - nothing you can adjust in there.
77mm, company, experience, job, k-mount, lens, pentax, pentax 77mm, pentax lens, repair, service, slr lens, time
DIY SDM repair! sveinmb Pentax SLR Lens Discussion 232 03-26-2023 11:42 AM
Flash door DIY repair (AF-540FGZ) using Legos mikeSF Do-It-Yourself 22 12-13-2021 03:18 PM
77mm lens repair indianswift Pentax SLR Lens Discussion 6 05-06-2018 12:29 PM
Sigma 17-50mm F2.8 Ex Dc Disassembly DIY Repair ? Iksobarg Troubleshooting and Beginner Help 14 03-18-2016 05:59 AM
1st Attempt @ DIY Spider Light... Das Boot Pentax Camera and Field Accessories 7 05-31-2008 07:28 AM
All times are GMT -7. The time now is 05:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
