Originally posted by WPRESTO I will just repeat and/or summarize some of the recommendations made above. 1) almost any macro lens in K-mount will deliver good to excellent results. The design of macros rapidly reached a high level decades back, and because of competition, almost every one made after about 1985 is very good; 2) AF is not necessary for most macro work, and commonly does not function properly in the macro range with the possible exception of long FL macros (150mm or more). Most of us who do a lot of macro routinely use MF even if the lens offers AF; 3) Probably the best bargain prices will be found in macros of about 50mm, for example, the 50mm SMCA f2.8 can sometimes be purchased at a bargain price. 4) unless you are going to do nothing but flower photography, if you intend or think you might do some insects, probably the best choice would be a lens in the 90~105mm range. 5) There are many good lenses in the 90~105mm range, but probably the most common, and probably most available at a good price would be a Tamron 90mm, any vintage even going back to an Adaptall 2 (if you can locate one with a PKA mount). 6) Although macro lenses made as early as the 1960's are very good, both ambient light and especially flash exposure will be much more convenient and quick if you get a lens that has "A" communication, that is, an "A" series or later lens, or a lens that is at least PKA compatible.
Great summary.
Pretty much any dedicated prime lens from the last.. 20, 30 years will give you decent, possibly amazing results. The latest few generations are all pretty much amazing, at least in terms of optics. Some have different features (like focus clamp, focus limiter, aperture ring), so these are important factors. If you want to use manual bellows or old SLR, the new DFA 100mm WR is not your best choice because it has no aperture ring.
That said, Pentax 50mm macro, 100mm macro are both great optical lineages, even back in FA and F series. Check locally what is available, and the marketplace here as well. I have DFA 100mm and it is a stunning lens. Even at its regular store price it is a fair price, because the lens really delivers amazing photos. And holiday sales are coming soon!
