Originally posted by yucatanPentax on the supposed lens composition of the early FA 43's vs later. Specifically, lead. Supposedly, earliest versions had lead in the glass, which was later reformulated.
I have heard many things about the early FA43, there was even a rumor that the early batch of 100 lenses in production had aspherical elements in them. This has been thoroughly debunked.
Originally posted by yucatanPentax Thought you may know something about the glass composition. Do you think the lead (if true) has any effect on the image?
This is much harder to prove, I have no proof but my instincts say: No. Leaded glass (over 5% lead by weight) is still in production (albeit in very small amounts). Hypothetically, to prove this non-destructively I could pull two lenses apart entirely and use an abbe refractometer* to calculate the abbe number of each lens element and compare each elements RI to early and modern examples of the lens, and see if there is any difference in the abbe number which would indicate a change of chemical composition (the geometry of the elements would be another, indirect way to tell) . However, an abbe refractometer is something I do not have - and they are expensive. An ICP-MS** would be quicker, and give a definitive answer to the chemical composition of the glass elements, but it would require both the elements from both lenses be subjected to chemical treatments that would in all probability, destroy them completely.
* you can get hand held versions of these for gemological use, but I doubt these would have the accuracy, or be designed for use in measuring optical glass. There are laboratory grade refractometers used for analyzing properties of glass, but they are big - and
expensive.
**Inductively coupled plasma mass spectrometer, again: expensive, and something I do not own...hey,perhaps I should start a gofundme so I could get one.
