Originally posted by RAART Digitalis Maybe you can post some examples and your impressions about that lens here?
I certainly can. However I have had the lens long enough to develop more than just an impression. Sigma has had a long history with macro lenses, especially making long focal length macros. The sigma 180mm has several variations - the first two are relatively rare in K mount: the 180mm f/5.6 APO Macro and Sigma 180mm f/3.5 APO EX DG, and the current Sigma 180mm f/2.8 EX DG HSM IF OS - which, sadly isn't available in K mount and probably never will be. I happen to own the Sigma 180mm f/2.8 in Canon EF mount, and optically it doesn't improve much over the f/3.5 version, in fact it is slightly worse*. the OS feature is handy but I wouldn't consider it essential.
Pentax K5IIs- Sigma 180mm f/3.5 APO EX ISO 1600 f/5.6 1/60th
Voigtlander also make a 180mm f/4 Macro SL which was offered in K mount. It is said to be not in the same league as the legendary Voigtlander 125mm f/2.5 APO Lanthar, but is still
excellent optically, and built like a tank. I have never seen this lens.
On APS-C format the Sigma 180mm f/3.5 APO is an excellent lens, with a generous working distance for skittish macro subjects and also studio macro work. The increased working distance the 180mm lens offers at 1:1(which is
roughly 180mm) is well worth the price. On full frame Pentax K-1 the Sigma 180mm f/3.5 is
superb.
Pentax K-1 - Sigma 180mm f/3.5 APO EX @ f/3.5 ISO 320 1/250th
The sigma 180mm f/3.5 APO is commonly viewed as the "poor mans" FA*200mm f/4 ED Macro - the FA*200mm f/4 Macro being one of the best lenses pentax has ever made. A few years ago a reviewer who worked with Canon DSLRs caught some flak for saying the Sigma 180mm f/3.5 APO EX was sharper than the Canon EF 180mm f/3.5L - Unfortunately for Canon, he was right, and his opinions have only been confirmed over the years.
Pentax K5IIs - Sigma 180mm f/3.5 APO EX Macro f/16 ISO 400 1/180th
It isn't quite as good as the Pentax FA*200mm f/4 ED Macro, but that shouldn't suggest you can't get good images from it.
Pentax K5IIs - Sigma 180mm f/3.5 APO EX Macro - ISO 320 f/5.6 1/250th
* 3 copies tested of the sigma 180mm f/2.8 APO IF EX DG HSM OS - 4 copies of the Sigma 180mm f/3.5 APO EX IF. Testing found chromatic aberration is higher on the f/2.8 version when compared to the f/3.5 version. This seems to be a characteristic of the optical design sigma is using, at 1:1 the aberrations are very low but get progressively worse at long focus distances with both f/2.8 and f/3.5 versions of this lens.
