12-08-2016, 06:07 AM   #1
K100D lens compatibility
I'm new to the forum so excuse me if this question has been answered before.
I have owned a Pentax K100D since 2007 and have had good results with its standard 18-55 lens and with the Tamron 70-300 zoom I bought at the same time. However, I would now prefer not to carry both lenses and have to keep swapping them (as I don't have a second body) and so am looking for a compatible 18-270 lens which will work with the K100D and allow auto-focus operation, which I have read may be an issue with the current Pentax 18-270 zoom.
Can anyone advise my best options, please?
12-08-2016, 09:32 AM   #2
NS_Sailor's Avatar
I have a K100D and have had great success with Tamron XR DiII AF 18-200mm F3.5-6.3 Macro that I bought used over 2 years ago.
The lens is out production but you can sometimes pick one up for a decent price on E-Bay. $150.00 - $180.00 Canadian
I've attached a PP HDR shot and an indirect sunrise taken with the lens
PENTAX K100D  Photo
PENTAX K100D  Photo
12-08-2016, 11:09 AM   #3
Digitiser of Film
BigMackCam's Avatar
Thread moved to Pentax SLR Lens Discussion
12-08-2016, 12:15 PM   #4
PEG Moderator
Kerrowdown's Avatar
I'll just say a quick welcome to the forum.
12-08-2016, 12:49 PM   #5
QuoteOriginally posted by 1martin2 Quote
Generally speaking, Pentax's compatibility policy is such that all older lenses will work on a newer body, but lenses newer than the camera may or may not.
The full compatibility is broken down here. A checkbox means you can use the lens without limitations in metering, and the AF/MF icon indicates the type of focusing available:
The Pentax Camera Lens Compatibility Chart
Here is a list of all Pentax autofocus lenses that deliver autofocus on the K100D:
Lenses with Screwdrive Autofocus | PentaxForums.com
What won't work:
Lenses with the KAF3 mount (look for SDM or DC in the lens name) will only work in manual focus mode. Unfortunately, the DA 18-270mm is part of this group. I'd recommend the older DA 18-250mm instead. To verify which mount a lens has, look under the "Mount Variant" heading in the specs tables on the page above, or in the lens database. Most new lenses are KAF3 because this designation means "silent AF only".
Retractable RE lenses (DA 55-300mm RE PLM, DA 18-50mm RE) will not be able to focus at all, and thus can't be used. KAF4 lenses won't work either because the camera won't be able to control the aperture.
TLDR: any lens with the K, KA, KAF, or KAF2 mount will work fine. KAF3 and KAF4 lenses are either not compatible with the K100D, or only manual focus.
By the way, have you considered upgrading the body at all? Something like the K-50 works with all Pentax lenses, and it will blow your K100D out of the park as far as image quality and performance goes
12-08-2016, 01:04 PM   #6
swanlefitte's Avatar
I bought the 18-250 with my k100d. I really enjoyed the combo. It gives decent results and isn't too heavy. I still use it from time to time. The main complaint is creep. It falls open to its longest size unless held or locked closed.
12-08-2016, 01:11 PM   #7
Thanks for the advice - plenty of research to do. I'm in UK so maybe not so many options available? I'll start looking.
12-08-2016, 09:25 PM   #8
UncleVanya's Avatar
To be sure is it a k100d or k100d super? The 18-270 works with the super version.
12-08-2016, 10:09 PM   #9
pres589's Avatar
I thought the 18-250 reviewed a bit better than the 18-270, right? I'd go looking for one of those used if that's what you're looking for.
compatible lenses, k100d, lens, pentax
K100D lens compatibility question cif Troubleshooting and Beginner Help 11 02-09-2012 04:00 PM
k1000 and K100d lens compatibility germar Pentax SLR Lens Discussion 8 09-10-2009 01:03 PM
Remote control F/K100D Super Compatibility? Ecosse Pentax Camera and Field Accessories 4 08-29-2008 10:32 PM
K100D and Nikon compatibility AlexTheodin Pentax Camera and Field Accessories 5 06-16-2008 10:23 PM
Lens compatibility of K100D ardabalkan Pentax DSLR Discussion 5 06-22-2007 05:24 PM
All times are GMT -7. The time now is 03:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
