Howdo folks. First proper post and it's a bit of a cry for help...
Splashed out 550 notes on a Tamron 70-200mm and trying to decide whether I have a bad copy or just unrealistic expectations. I'm not a pixel peeper and I don;'t care too much about sharpness as long as I get a solid picture, but wide open at 200mm it feels pretty much unusable due to a weird 'glowing' softness. Not 'soft' as in 'unsharp', but more of a wide bright glow/halo around details, like you get with a crappy teleconverter. It seems to get better as you back off towards wider angles, a little soft still at 70mm but more in the acceptable range. Whereas at 200mm it's noticeable even on a smallish thumbnail, an obvious haze that looks like a dodgy soft-focus filter. It also looks a little overexposed at 2.8.
I'm 90% certain it's nothing to do with front/back focus. Stopping down to f3.2 (or 3.5, see below) pretty much kills the softness straight away and from f4 it's sharper than Wolverine's nail clippers.
On a separate note, I can't select f/3.2 at 200mm. if I set it at a wider angle and then zoom to 200mm, it jumps to either 2.8 or 3.5. Is this a normal quirk of this lens?
Here's some examples, all taken at 200mm. Forgive the bland shots, just used my backyard as a test bench.
90% crop: f2.8
90% crop: f4
f3.5
f2.8
Basically, if you own or have used this lens...is this glow normal at 200mm wide open? I'm not a pixel peeper and I'm not expecting X-TREME SHARPNESS™, but this glowy thing is unpleasant and it's left me feeling a bit disappointed. I've got a week to make up my mind whether to return the lens, so i need a reality check to see if I'm just being fussy or I have a lemon here!
(PS: I'm not buying the whole 'oh yeah it's soft at 2.8, but it's great at f4!' thing. You can get a Canon 70-200L f4 for £50
less than this Tamron, and frankly that's a better lens in every possible way except maximum aperture. Obviously that's no consolation to us Pentax folks, but it shows that the Tamron is not worth the money if you're only able to use it stopped down...)
