Originally posted by Blacknight659 I am looking at other sample images of the F series and to my eye, it seems they produce a unique color rendition not found after this line up.
I've noticed this as well, particularly in the zooms. The F 70-210 particularly stands out in this respect. To my eye, many Pentax lenses seem to have a slight bias toward the magenta and purple in their rendering of blues, whereas the F lenses seem to have a slight bias toward aqua.
Here's a shot from the F 85mm f2.8 Soft:
Originally posted by Na Horuk Maybe the lens coatings were tweaked a little afterwards?
Pentax at some point attempted to attain greater consistency of color rendering among their lenses (this probably began with the M series). If you go back to the m43 Taks or the original K series K-mount lenses, color rendering is all over the place. I have four K series lenses and they all render color very differently. My four M series lenses are more consistent (although my M 20/4 is a bit of an outlier in this respect). The A and F series lenses seem to demonstrate an even greater consistency. I read somewhere that attaining greater consistency among lenses using different types and numbers of glass elements involves combining various layers of coatings in different ways --- essentially "tweaking" them, if you will.
Originally posted by luftfluss Of course, with software, we can approximate any color rendering we want, if we know how. But I'm the type of person who needs the lens to lead me by the hand - I'm no good at advanced colormongering.
I've been doing PP for over 15 years, and I've found that there are real limitations to relying on software to get the exact colors one might want. While it's easy to change blue to purple or yellow to orange, changing from, say, "Tamron" blue to "Pentax" blue is much harder, if not impossible. When you change blue to purple via software, you don't transition between every possible color tone between blue and purple. Many tones are excluded, and if you want one of those excluded tones, you're not going to get it out of software. Lenses have different color renderings because of subtle color casts. Such color casts will determine the exact data set that the sensor records. Software can only extrapolate from a given data set, so different data sets will yield slightly different results, even after "colormongering." If I find that a particular lens consistently fails to provide the color I want, even after post-processing, I get rid of it.
