08-01-2008, 07:44 PM   #1
sigma 17-70mm
I guess this is for those who have this lens. I just got it and did a quick test and I noticed that the corner sharpness at 17mm is pretty bad wide open. Is this typical of yours? It didn't really get better when I stopped down. Just wondering if I got a bad copy. Thanks
08-01-2008, 08:14 PM   #2
you should post your sample. 'pretty bad' is a relative term
08-01-2008, 08:39 PM   #3
Ok here's my quick test. The first is the orignal image and the rest are the corners. The first 2 crops seem the worst. They are the top 2 corners of the image while the last 2 are the bottom corners. Let me know what you think please. I have a feeling I might just be trippin over nothing
PENTAX K10D  Photo
PENTAX K10D  Photo
PENTAX K10D  Photo
PENTAX K10D  Photo
PENTAX K10D  Photo
08-01-2008, 08:51 PM   #4
the test shot is inconclusive. you should give your test shot adequate chance: use ISO 100, make sure the focus is dead-on. turn on flash or do the test with plenty of light. otherwise you're taxing the whole system and the rest of us probably would be just guessing...
08-01-2008, 10:22 PM   #5
deejjjaaaa's Avatar
QuoteOriginally posted by furby Quote
I have sent my copy immediately to Ronkonkoma, NY (Sigma Service Center) - I was completely expecting such or similar defect... Center was always good - but the left side was consistently clearly different from the right side... tested on brick walls and newspapers (from 17 to 70 and from f2.8...f4.5 to f8.0).
PS: and I did test on both *istDL and K10D so that Sigma will not escape by blaming anything
on specific camera.
k-mount, pentax lens, slr lens
Sigma 24-70mm F2.8 IF EX DG HSM - VS - Sigma 24-70mm F2.8 EX DG Macro Braciola Pentax SLR Lens Discussion 2 10-15-2010 04:54 AM
Pentax 17-70mm f/4 or Sigma 18-50mm f/2.8 or sigma 17-70mm f/2.8-4? shang Pentax SLR Lens Discussion 8 05-24-2010 05:30 AM
Sigma 24-70mm, Sigma 28-70mm, or Tamron 28-75mm? gkreth Pentax SLR Lens Discussion 7 05-23-2010 01:01 PM
All times are GMT -7. The time now is 02:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
