Originally posted by ivanvernon I recently acquired a Kiron MC7 2X Teleconverter for Pentax mount. I have not begun using it, but I have a question and would appreciate comments. The question is whether using a teleconverter does/should provide better results than simply cropping to increase image size. I have heard pronouncements on both sides of this question. I am sure the quality of the teleconverter glass makes a difference but wondering what other variables are at work.
I've tried a number of TCs over the years, and I've found success is a combination of three things:
1) Quality of the primary lens. A lot of people (myself included, 20 years ago) think you can put a TC on a consumer zoom and get a longer consumer zoom. It rarely works that way. The host lens has to have enough resolution that IQ is not lost when you enlarge the image with the TC. I had pretty much given up on TCs because all I got was mush until I tried one on a "star" lens.
2) Quality of the teleconverter. There's a reason why the good ones cost hundreds of dollars. Most 2x TCs (emphasis on
most) take a huge hit to IQ along with the 2 stops of light lost, and you are better off with a digital crop, especially if you have a higher-resolution sensor. It's more "it depends" with 1.4x and 1.5x TCs.
3) Quality of the light. When you are losing 1-2 stops of light, unless you have a really fast primary lens, you are going to bang into some kind of limit, whether it be having a fast enough shutter speed for the focal length or noise from having to use high ISO. You can't just slap the TC on for more reach - lighting conditions that were "good enough" for the primary lens may not be for the combination.
