Well...
That was a lot of replies overnight!
More to think about now!
Originally posted by dave2k I owned the DA L 55-300 but I was never very pleased with the IQ. I think the IQ on my Tamron 18-250 was better and for me that focal length range is preferred. In the end I decided that IQ was my top priority and I was willing to pay more and carry more weight so I could potentially make a sharp enlargement of any good picture I take. Back when I bought my used 60-250 I paid $900 so current pricing is a relative bargain. But it is quite a bit larger and heavier as others have stated. I used to use my 55-300 whenever I travel but now I take the 60-250. I have used it with a Tamron 1.4x converter with good results. If you think you might ever move to full-frame the 60-250 would be the lens of choice. I haven't even made the minor
modification to mine and it's pretty decent on full frame with just some vignetting to correct. Good luck with your decision.
Sound like you might have gotten a bad copy of the 55-300?
Originally posted by Theov39 If your main intended use is birds and wildlife, then the logical choice would be the DA*300. Outstanding quality and for those purposes you don't need a zoom.
However, it is a pretty specialized lens and not practical as an everyday walk-around lens. For that the 55-300 would be much better and the early versions are going very cheap second hand now. ($120-$150 range). Frankly, you need both
The DA*200 is a wonderful lens without peer BUT super expensive and in my view 200mm is too short for wildlife.
Yep, I've crossed the 200 off the list.
I've always wanted the 300 but if I'm getting a more expensive the question is 60-250 or 300?
Very hard choice as I know most animals are far off so the 300 might be a better choice.
Originally posted by monochrome I had the SMC DA200 and upgraded to the 55~300 shortly after it was released. The secret to good, sharp, vibrant images with both lenses is good light - actually, bright light - and a very steady hand. In good light with a high shutter speed either lens is sharp and contrasty, but they both get muddy quickly when light is poor and/or speed drops. At least that's my take.
I use the 55~300 now with K-S1 for just walking around and documentary shots. I don't have anything really good at 300mm, even manual focus.
Hmm... Most of the animals I encounter is near dusk, hence why I want a lens that's faster or I can shoot wide open.
Originally posted by normhead Hey bertweert, what about an A-400?
What about it?
I've considered this but I think I'd find the AF a bit slow
What sort of price do they run for?
And how big is it?
Originally posted by GeneV I have traveled with the 55-300, and have been very happy with the results. It is definitely an upgrade over the 50-200 in every aspect but portability. There are a good many bags in which you can carry a 50-200, but not a 55-300, especially mounted. The size and weight problem is even greater with one of the highest quality options, such as the 60-250 or DA*300/4 or even the A400. That being said, there is no lens which does the wildlife duty for me like the DA*300 plus rear converter. It is all a question of what you want to spend and how much you are willing to carry.
I can carry lot's just it won't be coming backpacking...
The DA 300 is a popular choice for wildlife.
Most people seem to like to use it with the TC making a 420/5.6
Wonder how I'd like the A 400?
Originally posted by BrianR So many choices. Are you still interested in getting a macro lens for one day? It's a much easier decision lens-wise. Buy one of the 90-105mm macros and you're done. Concentrate on photographing things with no wings and short legs that can't run away from you. This should keep you busy as you save up for a DA*300/4 or the D-FA 150-450, either of which should be 'forever' lenses and worth saving for.
Still want a nice macro. Only got eyes on one though so an easy decision. I think I'd feel limited with 100 as my longest lens?
Originally posted by ccc_ I have three copies of the 55-300 each rides on one body that it seems to perform best on
the weather resistance is initially what drove the purchases but image quality is what keeps them in use
tis lens is a good value no matter what you pay and it is pretty inexpensive right now
I like zooms and seldom use a prime, frankly they make my fun work
if I lived where you do I would want a longer lens and for the money the two big sigma zooms are the best bang for the buck
I got the 150-500 as it was disappearing from inventory and frankly I find it a wonderful lens
it performs better on my k50 than either of my k3s
I suppose every lens/body combination has a sweet spot
it's heavy and not weather resistant
I tote it around in a kinesis bag with a strap made from seatbelt material or carry it cradled across my body
it is too long and heavy to dangle from a strap
those were the downsides
the upsides include better stabilization in-lens than pentax's SR, quick,silent and accurate focusing and pretty remarkable IQ I(even nice bokeh, if that matters) f you do your part of the job
this year i'm going to pick up the hd150-450 and that will strain budgets and relationships
i'm totally satisfied with sigma but I WANT the pentax
either lens will give you an edge over what you are using now
ISO on body offsets any need for speed in the lens
as an added benefit the deeper depth of field will let you get a few more keepers
good luck deciding
Hmm looks like I'll be going to check this lens out...
Originally posted by pepperberry farm what an awesome lens the A400/5.6 is....
I'll be searching for this as well then...?
Originally posted by WPRESTO I used and still own the original version of the 55~300mm, and also a 60~250mm
1) IQ of the 60~250mm is definitely better, but it has less reach, it's much heavier and bulkier; it's much more expensive.
2) IQ of the 55~300mm is remarkably good for such a bargain-priced lens; it is small and light, very easy to take-along and hand-hold. You sacrifice some IQ and AV for a very large gain in convenience. As noted by UncleVanya, short of pixel-peeping images of exactly the same subject taken at the same time, it is very difficult to consistently identify photos taken with the 55~300 versus the 60~250, and if both lenses are at mid-range FL and AV (100~200mm @ f8) it is almost impossible.
If you don't need WR, used copies of the original version of the 55~300mm, which are optically identical to the current non-collapsible version, can be purchased for near-steal prices.
I like WR but I guess it's not mandatory...
Seems like the 60-250 is nicer in IQ but the 55-300 may be more convenient.
Originally posted by ccc_ I've added to images from this summer
both were taken in downpours
the black bear was bit of surprise as he magically appeared from it bit of brush (k3 55-300)
the grizzly apparently wanted to meet me (k50 150-500)
the point is the weather resistant pentax combo survived unscathed
while the pentax/sigma combo acted a little weird until it was dissembled and dried out
So I see that the WR has come in useful over the Sigma.
I'll still take a look at the Sigma though.
