01-02-2017, 11:38 AM   #1
Pentax bayonet mount for hoods - are they the same across Pentax lenses?
The hood that ships with the HD DA 18-50/4-5.6 is a bit too expensive and doesn't come with the slip-on lens cap. I mean - $40 for a tiny piece of plastic? I could probably print one out if I still had access to a 3D printer.
Anyway, I can find a screw-in 58mm rubber hood off of eBay, but I wouldn't want to keep fiddling with the hood and inadvertently mess up the retracting lens mechanism. So, I'd like to stick with a hood that utilizes the bayonet mount since it's already there.
Is there a lens hood that would be compatible with the bayonet mount and wouldn't cause too much vignetting? Is the bayonet mount the same for all Pentax lenses? Could I theoretically fit the PH-RBA58 (for FA 20-35/4) or the PH-RBD58 (for FA 28-80/3.5-5.6) on to the DA-L 18-50/4-5.6 lens?
Thanks!
01-02-2017, 12:14 PM   #2
UncleVanya's Avatar
They vary. Some overlap and interchange can be done but it is not easy to figure out without trial and error.
01-02-2017, 12:20 PM   #3
That's what I figured. When I shot Olympus 4/3, the lens hoods were all interchangeable because the bayonet mount on the Zuiko Digital lenses was the same...
01-02-2017, 03:34 PM - 1 Like   #4
Hello
It's not Pentax but would this https://www.amazon.com/dp/B01FVHTRH8/ref=twister_B01KHF69L6?_encoding=UTF8&psc=1 help?
Best regards,
01-02-2017, 03:38 PM   #5
QuoteOriginally posted by ddharriman Quote
Hello
Best regards,
Thanks - I actually found something like this on eBay and I think it would work. It's not screw-on, and should still allow me to use my lens cap.
I'll get it when my eBay bucks certificate comes in tomorrow! Thanks!
bayonet, fa, hood, k-mount, lens, pentax, pentax bayonet, pentax lens, slr lens
Remote unit 3rd party question: are they all the same? (tech) fstop18 Pentax Camera and Field Accessories 3 11-30-2016 11:04 AM
which of the Pentax bayonet mount lenses fit the K 50? LSAGuy Pentax K-30 & K-50 28 09-18-2015 09:56 AM
Yongnuo 560 iv. Are they all the same? shadmanaj Troubleshooting and Beginner Help 5 08-02-2015 10:14 PM
Are there any hoods on the market for the 50-135 that are cheaper than the Pentax? maxxxx Pentax SLR Lens Discussion 13 03-15-2015 10:44 PM
Pentax SDM lenses, how much they are really worth or are they worth it? Pentaxor Pentax SLR Lens Discussion 20 01-17-2015 11:32 PM
All times are GMT -7. The time now is 03:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
