01-10-2017, 10:03 AM   #16
I've just received my copy today. Looks really sharp on my K-1 right from the beginning (f2.8)! Good start!
01-10-2017, 10:05 AM - 1 Like   #17
normhead's Avatar
It's an addictive lens. After a while, I had to stop putting it on the camera. Once on the camera it controls your mind.
01-10-2017, 12:31 PM   #18
I start understanding why
Hope to post some first results soon.
01-10-2017, 12:52 PM - 1 Like   #19
Yes, this lens is addictive!
Looking forward to seeing your results
01-15-2017, 06:23 AM - 1 Like   #20
Alright, very first test shots with my model, good old buddy Bruno .
I like the how it handles on a K-1, the weight is reasonable, so is the size. Just the hood could be shorter. I'm wondering whether it's because it was meant to be used on APS-C bodies?
Anyway, hope you like what you see. I'm pretty confident that it will be a keeper. Focus is spot on as far as I can say. Even f2.8 works.
PENTAX K-1  Photo
PENTAX K-1  Photo
01-15-2017, 10:45 AM   #21
Once again in b/w. Less distracting.
PENTAX K-1  Photo
01-15-2017, 11:36 AM - 1 Like   #22
UncleVanya's Avatar
Bruno is very stately.
01-16-2017, 07:03 AM   #23
Thanks! Yes indeed, he really is!
01-17-2017, 11:31 AM   #24
Here's one I shot this weekend with my new DA 200:
PENTAX K-1  Photo
01-29-2017, 06:17 AM   #25
I fall in love with my DA*200
PENTAX K-1  Photo
01-29-2017, 06:33 AM - 1 Like   #26
Driline's Avatar
QuoteOriginally posted by zeitlos Quote
As they say in Deutschland Vunderbar! The DA *200 also makes for a nice portrait lens as well.
01-29-2017, 07:02 AM - 1 Like   #27
normhead's Avatar
QuoteOriginally posted by Driline Quote
Especially on a K-1.
01-29-2017, 07:42 AM   #28
Which shutter speeds (and then aperture / ISO) do you use with your hand-held DA 200 mm?
My handheld pictures with DA 200 mm are not sharp enough, while tripod is not practical with toddlers' shots (I try to use monopod with DA 200 mm but find DA* 2.8/50-135 mm more handy, esp. DA 200 mm has no 1/2'' screw socket nor tripod collar).
I try to use 1/160 sec with DA* 50-135mm at the long end (indoors with flash, as 1/200 sec shutter calls very limited range high-speed flash mode) up to 1/640 sec outdoors, which requires a lot of light (sun or bright skies) not to go beyond 1600 ASA.
01-29-2017, 08:04 AM   #29
Just press "View Picture EXIF" and you can access the most important data.
Well, I haven't used it very often so I cannot say if it's problematic in terms of shutter speed and unsharp results. So far no problem here. (Quite the contrary: I'm stunned how sharp this lens is, even wide open)
01-29-2017, 10:10 AM   #30
UncleVanya's Avatar
On my k-3 I have shot very low shutter speeds without issue.
A few in this set are as low as 1/125 but I've shot slower with good results. Single In December 2016 (DA* 200) | Flickr
70-200mm, da200, f135, k-1, k-mount, pentax lens, portraits, sdm, slr lens, tamron, vs
Pentax FA135 2.8 vs. F135 2.8 zeitlos Pentax SLR Lens Discussion 34 05-27-2018 12:40 PM
Advice Wanted: Pentax 70mm f/2.4 or the SMCP-FA 77mm f/1.8 or ? for BEST PORTRAITS? CeciProAm Pentax SLR Lens Discussion 85 02-06-2015 04:18 AM
Should my next lens be the F 135/2.8 or DA200/2.8 pcarfan Pentax SLR Lens Discussion 17 05-06-2009 02:45 PM
All times are GMT -7. The time now is 01:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
