Originally posted by Shakey In the end I don't want to jump the gun and buy something I'll regret either way.
The problem with long lenses is that there is no such thing as cheap , long and good, unless you are lucky to find a good copy of a second hand lens (like norm with the Tamron 300 f2.8). Usually, cheap long lenses are slow or not so sharp. You can get a Sigma or Tamron long zoom but you nearly always get sharpness drop in the long end. Usually, the longest focal length that's still priced around $1K and reasonably fast is about 300 f4 or 400 f5.6 (DA300+TC) (same situation for Nikon: 300f4+TC, and Canon have the 400f5.6 for around $1K), if 400mm is long enough for you. Beyond that 400mm, you have the 500mm and 600mm primes, prices increase rapidly. There is the Kowa Prominar solution, deliver fantastic image quality from what I've seen (they compare directly with Canon FL lenses), with 350mm, 500mm and 800mm, is price around <$2500, but it is manual focus, although it is easy to manually focus (I've tried one), and they have the adapters for Canon, Nikon and Pentax. There is also one DA560 Pentax currently discounted at SRS microsystems (UK dealer) at about $3.3K (about 20% cheaper as anywhere else), or there is the Sigma 500 f4.5 around $4K+ if you can find one.
