Originally posted by jeffrey.wetherill So am I safe to assume the following .... in general, using a DA lens on a FF camera reduces the megapixels to approx 15 because you are only using a portion (cropped area) of the FF sensor. It's NOT that image quality is being degraded. Rather, the megapixels are reduced because you are using LESS real estate (i.e. a portion) on the FF sensor. Is that correct?
No, your are still missing the point. The lens might make an image that is 36mp, 30mp, 28mp, 24mp, 15mp or any size in between. You have no way of knowing without testing each lens in FF mode. The CAMERA if set in crop mode will produce an image of about 15mp with ANY lens regardless of whether it is DA or FA or DFA. It does that by throwing away anything outside of the worse case APS-C image circle.
Lens has nothing to do with crop mode. That is purely a camera function.
Note that you can use a FF lens in crop mode and achieve smaller images, and a faster burst rate. But this has nothing to do with the lens, only the camera mode.
